Good choice on tires! :rockon: How you liking them so far?
I went through two sets on my 2008 Jeep Rubicon Unlimited and loved them. I am currently running Firestone Destination A/T LT275/75/r17's. I am putting this on as a spare and will likely put matching BFG's on all four corners once the Firestone tires wear out...unless someone buys them from me...hint hint...;)
The Firestone's are great tires, but they seem to hydroplane a lot easier than the BFG's....could be the width of the tires or maybe just the nature of the 4Runner...not sure.
Cleaned my inside temp sensor. I would recommend it if your heat is acting up and it's just good nature. I clean my vehicle a ton. And this is how dirty mine was
New rotors and pads.
Had a noisy rear passenger side brake. Found worn pads and warped rotor, so replaced both sides. Was extremely happy not to find seized pistons on the calipers, which got a good cleaning while I had them off.
[MENTION=97462]jgmx893[/MENTION] and i went to cars and coffee. need more toyotas there but i guess it was to cold for most
Washed her for the first time in forever. Every time I wash I'm reminded of how crappy the paint is. I've really got to figure out a solution to the rust that's developing around the A-pillar chips. Suggestions?
I also took off the nerf-style running boards. While I like the look over the stock boards, I think they collected more dirt & dust on top. I also think the stock boards protected the lower body more. If my daughter can get in/out without the running boards, then they're staying off.
Modded the rear compartment to show my amp install. I removed the stock sub and put the amp in its place.
Since it got up to almost 50 this weekend I actually hand washed both cars this weekend, and sprayed the crap out of the undercarriage. . . . take that Magnesium Chloride!
Ambrose67
