Twerk it
2003 SR5 4runner
3inch Rough Country lift
285/75/17 Dunlop Fierce Attitude
FJ Wheels
Offroad Adventures Roof Rack
So nice. I'm ordering.
How many bulbs per dome?
Did you use the same bulb for the door?
Do they just fit or do you have to do any mods to get them to work?
1 bulb per dome
Door/tag bulbs are #194
Every bulb was a direct fit replacement - no modification at all - 15 min job and looks awesome
Big stuff today!
Well here it is...
Radflo 2.5 extended travel coilovers with 700lb coils with external reservoirs and brackets
Radflo 2.5 rear shocks.
Spanner wrench
installed a light bar in the lower grill. still waiting for the oem looking switch rather than the universal one that came with the light
Put on some spacers. 1.5" in the rear, 1.25" in the front. Allpro spacers. 275/70/18 KO2s on 2/3 Toytec lift. The tires rub terribly on the front bumper now after the spacer install. Will need to get some dremel bits and grind some off.
Painted the Red JBA upper control arms...
Did the USB Power mod.
Now to figure something else out for the other two spots. :)
Anyone ever done a garage door opener mod there?
Duuuude! How? Where? I needs to be in the know here!
Love it man!
Thanks! I got them from Tiregraficx. I haven't seen anybody with them yet and I like the way they pop!
Installation is kind of a pain though. I have only the driver side done. Hopefully work on the other side tonight.
Installed a USB charger today that has a digital display in that square. Shows vehicle voltage when running. I was going to go with a dual but I wanted at least 2 amps charging. I noticed that all the duals were 2amps total, splitting it to 1amp each.
Sent from my SM-G935V using Tapatalk
Went to go for a drive when I noticed this on the drivers side.
Anyone here have this problem? I have no idea what it is.:confused:
Replaced what appears to be the 11 year old OEM plugs with 133k on them.
I found a 30% off coupon for advanced auto and put in the same Denso plugs.
$8 light-duty cargo liner - quick and easy DIY
Problem: the rubber bottom of the original 2005 cargo mat with the 4Runner logo had deteriorated to the point that it would continually release small particles that had to be vacuumed, so I got rid of it.
Use case: light duty - keep things from sliding around in the trunk. (I always keep the double decker in the down position.)
3mm 68" by 24" yoga mat from Walmart:
Cut in two 34" halves, then trim each half to required 20.75" width. Cut resulting strips to 20.75" length. Put everything together with duct tape like so:
Works well so far; everything stays put again.
Ambrose67
