Put together a LED light harness for the engone bay today - surprisingly bright, and less than $10.
Sent from my SM-J727V using Tapatalk
Changed the spark plugs. Apparently the previous owners thought it was optional or something[emoji58]
‘07 with 187,000 miles and what would appear to be original plugs
Finished my lift finally. Hoping the rear settles a little. Front fenders 37", rears are 38". The fronts have been on for 2 weeks though. Should I wait to get it aligned in case I need to raise the front more?
Finished installing my [MENTION=41439]victory[/MENTION]4x4 molle panels
Took the bumper off to repaint some spots I missed and scratches are starting to rust. Might re torque the header bolts while the paints drying.
This was yesterday and the day before but I got the front part of my dash cam and radar detector installed and hardwired.
Got the driver side speakers tweeters replaced on friday and the passenger done yesterday. I'm happy with how I mounted the tweeters. After researching on here I had a plan then when took the stock tweeter out I just pulled it all apart and used that. Easy enough, just had to wait for the metal to cool down after I melted the glue to get the magnet off
Sent from my SM-N975U1 using Tapatalk
Love my 4runner but a major issue has been the front cup holders. Going around corners with one hand on my coffee mug to prevent it from falling over has been a major irritant let alone any type of gravel road with washboard.
Took only 5 minutes and it's super simple. I just cut a thin strip of grey packing material, stuck it to double sided foam tape and then attached to the inside of the adjustable levers of the cup holder. All it does is reduce the gap between the lever and the container. Not perfect, but for about 10 cents, works pretty well.
Random question but is that trim factory? I like it better then the silver on mine!
2006 SR5 4Runner 219,000 miles W/ 3" lift up front.
Installed new upper & lower Control Arm Assemblies, and new Tie rod ends.
Then had an alignment done. I cant decipher the alignment paper so im not sure if its ok or not....
Created a work of modern art.
Actually, that’s the remainder of my X-REAS that I’ve needed to remove since swapping out my suspension last year. I also rotated my tires since Discount Tire is providing urgent services (flat repair, etc.) only.
That on a Limited? I think that's what my trim looks like.
What I did this weekend was pull the rear bumper cover off to see how the frame rails were doing. 6 hours or so later I had new steel welded in to where I found rust holes. I posted some pics in the thread below.
https://www.toyota-4runner.org/4th-...eir-4runner-frame-replaced-2.html#post3465004
I have a 2004 Limited, mine looks somewhat similar in color but it is different, mine looks more like a green granite, it is speckled and not streaks like his.
Interesting, guess I'd have to look closer at mine but I assume it probably looks more like yours because of the age. I think it is more speckle-ish.
V8 badge relocate. Too much drivers lean, had to center the weight. [emoji23][emoji1787][emoji1787]
Sent from my moto g(7) power using Tapatalk
Spot cleaned the carpet, and replaced my missing climate control bulb. Getting ready for a wash and clay tomorrow!
I finally got around to replacing my exhaust, ended up going with a Gibson exhaust thanks to this forum. Definately sounds different, a little droney but I could care less about sound, I went SS so that way it doesn't rot out in 5 years.
Is there a market for the unused parts? V8 downpipe and 5th gen exit pipe were never used.
