More WITH the T4R....
After using a couple zip ties to try slowing the tide, I replaced my rear sway bar end link bushings. It took me a while to find the correct size for the Skyjacker SBE702 but alas my end links are whole again. It's not the perfect fit as the washers don't cup this as well, but they are slightly thicker which I imagine is better than not. I also found one of the eyelet sleeves is corroded/deformed so the obscure parts search continues.
Flushed out my power steering fluid and replaced the reservoir. Other than being dirty and yellowed it was fine. But it was making it harder to accurately see the fluid level so it had to go. It was a good excuse to use my new OEM Tools fluid extractor.
The two hoses have gotten a bit hard, but no immediate need to replace. I'll have to do them soon.
Replaced the transmission fluid and filter from my new to me 2006 (230k miles), oil was dark but no metal residuos, I was experiencing a noticeable shudder at 30_40 mph , shudder is gone !
replaced the blower motor after it randomly died. was still getting 13v+ to the plug so it was pretty obvious. had to visit 3 parts stores to find one.
took about 10 minutes, awkward to get to the 3rd screw but just use a ratchet.
i had a clicking that I was positive was the ac servo that i had been putting off fixing, but i dont hear it anymore so maybe i got lucky.
Bought a new (to me) '07 Sports V8. 5 days later, I backed up onto a job-site, right in to a gas pipe that our excavator didn't completely remove. Punched a hole into my trunk hatch that was otherwise perfect. Well, applied some rust spray and slapped a Rising Sun sticker over it.
I also purchased all the necessary flux core welding equipment to learn a new skill for the future prospect of buying a Coastal Offroad front bumper real soon.
Winced when I saw the pic, at least spare tailgates should be easy to get hopefully.
I'm going to keep it as a battle-wound.
The wreckers want $400-2000 depending on the condition. Such a scam. I'll be looking for private sellers for sure.
Left turn signal was out, driving my sister-in-law around. this morning I checked and the socket had no bulb in it. I bought 2 and it would be behind the battery. got it working and the old bulb is in the headlight housing.
___________________
2007 SE V6 titanium still 50K
___________________
I saw where someone had this issue once. They made a noose with a plastic drinking straw and some I think nylon string and was able to fish the bulb out of the housing.
Replaced spare wheel carrier with OEM chain-based one
My mechanic recently pointed out that the steel cable holding up the spare wheel was starting to fray and I might eventually lose the wheel.
Today, he replaced it with this newer chain-based part 51900-60280, which supersedes the cable-based part 51900-35380.
Spare Wheel Carrier Assembly #51900-60280 | Autoparts.toyota.com
I ordered it on eBay directly from Japan, and it arrived in Chicago after six days.
TOYOTA GENUINE 4RUNNER LEXUS GX470 2003-2009 SPARE TIRE CARRIER OEM 51900-60280 | eBay
Seems to be a very solid upgrade.
New mod!! Installed the new Apex Designs quick disconnects for the front sway bar. Pricey, but hey we make money to spend it, right?
Cup holder lights have been out since I bought the truck like a decade ago and I finally got around to replacing them.
Used these LED bulbs from amazon:
Amazon.com
Did the lazy method and just used a pair of needle nose pliers to pull the pigtail out of the small gap in the center console.
Cleaned the area too, it was nasty back there. So much grime built up that the clear window for the light was almost opaque
delislerebecca
