Looks like pvc valve and someone's just seafoamed it.
Anyone know what can happen if the truck is driven around with the hose/valve uncoupled? Any fix for it?
For a second I thought this was a joke.
What's your gas mileage??
And what do you expect your gas mileage should be??
Trip computer says I'll get 320 Miles to a full tank ( gas pump stops by itself). I'm sure I used to see 390-400 on the display. Hand calc shows about 13-14 MPGs mixed driving.
I've actually driven it down to the last ounce of gas till it died!
How many gallons are you putting in each time? I put in about 20 gallons give or take after the light comes on.
Driving 320 miles on 20 gallons comes up to 16mpg which is about right. Plus the trip computer isn't the most accurate thing ever.
zstampe: I fill it up till the pump stops automatically so theres no variation in the amount of gas in the tank, that's the constant.
23 gallon tanks divided by the trip computer's 320 = 13.91 miles per gallon which is very low even for pedal mashers. Isn't that how the math is done?
Are you really running the tank dry and using up all 23 gallons? I think your numbers are off.
Ran the tank dry once. Every time I fill her up I reset the trip odo and take those miles into the equation the next time I fill up, wash/rinse/repeat...
