What hardware is needed to install running boards(2002 sr5)
ShariD
We removed the running boards prior to Bettys (2002 SR5) first trip to Uhwarrie 3 years ago, here's the problem, i want to sell the boards but I can't find the bag of hardware. What's needed to install them, nuts,bolts, mounting brackets?
Hopefully you just unbolted the boards from the brackets that are part of the body. It's six bolts and nuts per side that you're missing. I don't recall the size.
Thanks for the info, no bolts or nuts on the boards, and nothing on the truck.........you've been a great help, at least I now know I only have to figure out SIZES........anyone, anyone, know off hand what size bolts and nuts I need........?:eek:
I believe they are 12mm bolts 1/4 diameter 1/2 inch long corse thread. Could be wrong but I know the heads were 12mm.
So I just checked our "other" 2002 TR4 to compare hardware, when I crawled underneath, I just knew that I would be able to check the mm size, I assumed they would be the same since we have the same model year but they looked completely different.......BUST, I was wrong.
Depends on what if any flares you have, the black sr5/sport flares have 2 6mm .10 thread bolts that are about 2 inches long. The rest is all 8mm .10 thread nuts for the mounting brackets to the under body studs.
Found it!
Thanks for everyones HELP!:hippie:
Just for future reference, the size of the heads is not the bolt size.
sorry next time i'll make sure i don't respond so late at night. that way I can make sure i can say head size instead of bolt. my bad for trying to help...:dammit:
brendaglores
