what is the easiest way to swap out front and rear diff gears?!
if i had to do it all over again i would think swapping the whole rear axle is easier than just swapping the rear diff. but then again you cant get in it and clean it all out. if your just gonna swap it in the truck i would use a floor jack to break the silicone and lower it down.
the front is a pain in the a$$ if you dont drop the front crossmember "cross member the diff is conected to" . after you unbolt everything just use a floor jack to lower it out and then do the oppisite to get everything back together
im trading it with a guy in cali so i guts need to take the internasl out
why cant u trade the whole thing??? it would be way easier u need special tools to get that done right, if its not done right alot of bad things can happen....
It you don't get your back lash right on your gear's you will blow them fast, if you don't know what i'm talking about have a shop install your gear's.
Pull both 3rds, tell him to do the same, and send them whole.
What he said.
But i have a question, why are you trading? Did you get picture's making sure his gear's are good and not blown nor missing any teeth? What ratio does he have and what ratio do you have?
What he said.
he is using his as a dd and wants 4.88 he said his are in good condition...he hasent taken them apart yet though
Yes but some people swap them for a solid axle. Is his IFS to?
to be honest i didnt even ask but i will as soon as he gets back to me. im 17 yrs old and as soon as i herd this i was like this is such a great deal...didnt even think bout that. good looking out man!
Welcome, you got to make sure of that cause if not it's going to be a waste of both your guy's time.
