What suspension kits so you suggest for a 3" lift?
Get the toytec, Looks better, feels better, will be beneficial in the long run :banana: better than the Daystar spacers you were talking about getting a while ago
What tires and size are you planning on running?
right now I'm running stock size BFG A/Ts... but I plan on getting bigger tires in the near future as well... I need to figure out how big I can go with a 3" lift and wheel spacers.
Get the toytec, Looks better, feels better, will be beneficial in the long run better than the Daystar spacers you were talking about getting a while ago
Are you talking about the ultimate lift, if so, why do you recommend it, why you are running the superflex?
Do you have 17's or 18's? :shrug: It looks like 17's in your avatar. With some trimming you can fit 285/70/17's.
ah, thanks for clarifying. So what it really comes down to here is adjust-ability: Toytec ult, vs less money: OME 885's+spacer/Superflex coils/Bilstein 5100's.
Are you talking about the ultimate lift, if so, why do you recommend it, why you are running the superflex?[/QUOTE]
Yes because its a complete kit, For one, Bilstein makes some of the best shocks in the world. 2. With toytec you get the free adjustability to your secifications unlike with the OME your going to get what you get and will have to add spacers to adjust ride height. As to the "ultimate kit" In my case I upgraded to the Bilstein 5125 rear shock because they are longer because my back is lifted 3"(soon to be 3.5). I chose the superflex because the 895's are pretty stiff and make for a bumpy ride with no rear weight. Yet my 2-12's,Amp,Box, and high lift come in around 125lbs, The superflex with 1" spacer's are smooth and get the job done fir ride/clearance for me with 35's
I am still saving for my lift but I found if you don't need the adjusting ability of the coil overs you can get the bilstein 5100 from shock warehouse for $50.00 less than toytec then get toytec/eibach front coil springs and the toytec rear springs whick comes out less than the 3" fj lift spring set plus you can get the discount with the listed code at toytec and shock warehouse has free shipping
this is what I got so far and it should be less than 700 for all
or am i forgetting something?
Hello everyone!
I've decided that I want to purchase a suspension kit for my 4runner, and I'm looking for about a 3" lift.
So my options seem to be an Old Man Emu suspension kit, toytec ultimate kit, etc.
From personal experience, what would you all recommend. I would not like to spend more than $1200.
:cheers:
This might be slightly over your $1200 budget if you can save up a little more ($1390) and go with Radflo's from Overland Warehouse. They were developed and tuned specifically for the 4runner by 4runner enthusiasts. In addition, both front and rear shocks are fully rebuildable. Excellent product and these guys stand behind what they sell.
Full 2.0" suspension kit
wow toytec lowered there price on the shocks now it comes to 670 or something like that
are aluminum top spacers required?
for the coilovers @toytec the cheapest your going to get the front and rear for is the 1,000 price range
Think Im going to go
Front: OME 884 light front coil springs +top spacer
Rear: Superflex Rear coil. Rear shock options: 60020_(For_Toytec_superflex_rear_coils)
That comes out to: OME: $828.99
i could always get adjustable front coilovers from bilstein/tortec instead of 884s though, that a decision I need to make. I hate deciding, I suck at it :roadkill:
If your Anal on how your runnner is going to sit, get the coilovers. I lost alot of money on spacer lifts and adding spacers to try to correct my drivers side lean, when i should have just done it right in the first place
Deno91
