What type of bulb in the door on your 5th Generation?
ic0517
I'm trying to get good info to the eBay seller yitamotor; I think he has 4th generation and 5th generation mixed up.
But I am sort of a loss, I only know about my 2013 Trail Edition.
2013 TE has T10 wedges in the door. I can update with pictures later if need be; its too darn cold in Chicago to be messing around with taking anything apart, but I do have some wedges sitting around some where, coat pocket, change thingy.
I just installed interior LED bulb kit. Pretty much everything except the roof door light and two trunk lights are wedge type t10 bulbs.
Also another tip, when removing the housing for any light. Look closely at the lens, you'll see a little triangle on the end where u pry to remove it from the door. I used the YouTube guide and it does not mention this, wish I knew bc I chipped one of my lens.
Anybody with a 2010, 2011, 2012?
Anybody work at a dealership and know, yeah they are all T10 wedges in the doors of the 5th gen?
2012 here, yes they are the T10 bulbs in all 4 doors. As stated above, the only ones that are different are the dome and rear hatch lights (not including the vanity lights, because my kit didn't come with those, so I have not seen them). Careful taking off the cover for the door lights. In mine, you pry from different sides, depending on weather or not its the driver side or passenger side doors. The you tube tutorial did not mention this (or it may be different in the 14+ ?)
So Mr. Muppet is saying his 2015 has wedges in the doors too?
So 2010, 2013, 2014, 2015 all have wedges in the doors (not the rear hatch)?
I have yitamotor's 5th gen LED kit.... the kit is completely fine for 2015.... no issue.... map, vanity, doors, side mirror, dome, hatch etc... ALL FINE.
194/T10 @ everywhere BUT 1x dome and 2x rear hatch
3022/Festoon for 1x dome and 2x rear hatch. his 6LEDs Festoon is a tad longer than our stock 3022 as seen in the following pic; but they did go in "OK" for me. If he can source "shorter" Festoon, that will be perfect.
(not included officially)
921/T15 @ 2x reverse light, yitamotor kit comes with "extra 194/T10", and you *can* use a 194/T10 in the 921/T15 socket. Altho, they weren't too bright, may even be worse than stock 194 halogen bulbs.
IMHO, not the best quality, but cheap and does the job, for $20 (does feel like a $5 - $10 quality tho)..... I am not ready to spend $100+ on this.... I am fine recommending this, as long as what you guys know what to expect..... he is a good vendor and will take care of you for ANY ISSUES you may have....
Oh, BTW, I am *still* looking for a better reverse bulb...... until my Gobi Rack with dual Rigid SR rear rack mounted (I think I may do 1 diffuse & 1 flood).....
