What wheel spec do I need?
FOGO DE CHAO
I've been all over the map with what I'm going to do to my 22 TRD. Ya'll have been very helpful though so thank you.
Skipping over a bunch of stuff, I think I'm going to put a Cornfed 1" spacer on the front to level it out to start and see how things go. It's probably really a .5" spacer to give 1" lift and I like that it doesn't compress the suspension and is top mounted.
I'll stick with 265/70's but get something like KO2s, Open Countries, etc. I like the look of the stock wheels but they are kind of narrow and no offset. Don't think I should do wheel spacers because it's not ideal so I want a wheel that bumps the stance out a little bit without any rubbing issues.
One example is say KMC Summit wheels. 17x8.5 with 0 offset. Would this fill out the width some since they are wider then stock? Or no because tire size is the same?
AndiGarage
