What's the best 2-DIN Nav HU?
jelgas said:
Hey davisc2, did you ever get the reverse Sensor wire hooked up..? You mentioned you used that guide to get the speed sensor hooked up was there a reason that the hook-up for the reverse sensor in that guide wouldn
Re: AVN5435
NND said:
With the Eclipse navigation system is it possible to still have the center center working? As the sound is noticablely better when I use the center speaker on my current factory JBL system. I'm a newbie and read through several post and realized that it's a pain to upgrade the system, but the system looks worth the hassle. Also, do you recommend adding an amp to the system? Currently, I have a JL Audio sub hooked up to the factory unit as the factory unit was lacking bass.
No, the eclipse unit is just like any other aftermarket head unit (it doesn't have surround sound like the factory JBL). I'm sure you can somehow patch into the left or right channel of the normal speaker output and send it through the center channel, but I doubt it will sound very good.
Yeah, I'd recommend getting an external amp for the front/rear/sub speakers. That's what I have hooked up right now. I had to do that because I had the JBL system (couldn't use the factory wire harness and had to re-wire all the door speakers). I figured since I had to re-wire everything anyway, I'd get separate amps so I wouldn't be powering everything off the head unit. If you don't have the JBL though, it would be a lot easier to patch into the factory wiring harness and run your speakers off the head unit itself.
Lizardking said:
Found out today that only the AVN5435 is Sirius ready the AVN5495 is not Sirius ready..Now that really bites!!!
DUDE! That's hard to believe. Can anybody confirm this? I'm not talking about seeing it in another post or board.
Can anybody who works at or has a buddy at a car audio shop confirm this? It just doesn't make sense.
I thought it was hard to believe too so I called Eclipse and they confirmed that only the 5435 has the Sirius not the 5495...
davisc23
davisc23,
I just ordered the 5435 so if you don't mind I have a couple questions.
1. Does the Sirius sound good? After reading your post I may just upgrade to the 5495.
2. Does your unit have LPF/HPF settings?
Re: davisc23
Lizardking said:
davisc23,
1. The Sirius does sound good, not great, but good enough for me. It's not CD quality, but it sounds better than the XM MyFi I had hooked up to the line-in previously.
2. No, it doesn't have any filter settings at all. I kind of miss that from my old alpine, but my amps have filters built in so I just use those. Another little quirk is that the EQ settings aren't saved per source (FM and Sirius can sound very different). There are 5 customizable EQ presets, so you can switch back and forth between them when you switch sources. Even without those tweakable settings, I think the overall sound quality is better than my old alpine 9813.
Re: Re: davisc23
I'm coming from the Kenwood Excelon KVT-915DVD so I'm a little skeptical on the SQ of the Eclipse compared to the Kenwood.. The 915 is supposed to be the most advanced audio/video deck on the planet. However I love Eclipse products and pretty much own Eclipse products. I called my dealer and asked them to order the AVN5495 instead and had them throw in a external Sirius tuner.
davisc23
Does the 5435 have any bezel at all with it? Some kind of ring that snaps on after you get the dash back together?
Davis,
Can you tell me if the lights on the unit match up with the rest of the vehicle...I am very interested in this unit...
jelgas said:
davisc23
Nope, doesn't come with anything like that. I'm still looking for ways to fill in the gaps on the sides.
doctob said:
Davis,
No, they light up green. It doesn't really bother me at all since the bright nav screen overpowers everything on the dash anyway.
davisc23 and anyone else that might be interested, I'm making a bezel/adapter/cover plate for this thing. I don
You can fill in the gaps by getting those adpaters sold on Ebay for Toyota's. As for the 5495 Eclipse told me today that it won't be released until end of April or May. Later in the year they plan on making the 5495 Sirius ready.
Lizardking, look at the pic posted earlier in this thread, there are gaps at the top and bottom as well. I don
Jelgas, would your cover plate be disigned for the JBL or the base stereo system. If you could make it for the JBL system, I would definitely be interested.
On another note, does anyone know the approximate price difference between the 5435 and 5495? I'm undecided between the two as I'm thinking if I hook up RCA cables to the 5435 and run it to the the tray between the two front seats and hook up an MP3 player may be adequate. Also, by doing it that way it would be one less thing that could go wrong. Any thoughts?
Tysonjones
