Whats the Typical Lifespan of X-REAS?
KP Texan
Just wondering when I'm going to have to change out the X-REAS shocks on my 4Runner. What lifespan have you guys seen before they leak?
They still seem to be good at almost 90K miles, and are leaps and bounds better than the stock shocks I had on my 2018 4Runner ORP when new. Guess I'll probably retrofit some 5100's when these are done.
Mine started leaking around 70k miles and were replaced under warranty. Now I'm waiting for the replacements to start leaking so I can toss a lift on it.
Mine was replaced under warranty for a slight leak at around 47k miles. Mine did see a lot of rough fire roads etc. so it was expected.
Mine is starting to leak, the rear shocks. I'm at 92k on my 2013. Just bought someone's 2019 TRD Pro suspension to replace it with.
Thanks for the replies everyone! When you noticed it leaking, was there oil on the garage floor, or did you just see some oil around the shocks?
All 4 of my shocks started leaking around 45k. Though I had a spacer lift which may have contributed to an early failure. Oil started to coat the shock bodies with oil pooling around the top seal under the boot. Removed and went aftermarket.
On mine there was a slight amount of oil coming from the fitting at the top of one of the front shocks. It just made a drip line down the shock with no oil on the floor. If it was not for all the dust from the fire roads making it darker no one would notice. It really did not need to be replaced but the dealer mentioned it during an oil change. The service tech told me it was going to be expensive and quoted a price of around 3K or so to replace the system. I then mentioned I had the extended warranty and he said it will be free. I got them to put on a small spacer lift on the front while it was apart also. On a side note I notice the new system is not as harsh riding as my original xreas.
That’s awesome! You lucked out. I’ve heard it could be as much as $5k!
My fronts are leaking now at 60k Km's,it will take two weeks to get parts from Cali. i also only noticed it because dusty road i have been on lately.
For everyone whose XREAS has leaked or otherwise required replacement, did you notice a difference in handling or just the leaked oil on the equipment?
On my 4th gen, they're still going strong. I haven't had to touch them and that rig has 210K kms. I had the brakes/suspension checked over by a mechanic also maybe 6 months ago.
Good question! I want to say I've actually seen a tad bit of oil leaking from mine, but the suspension still feels tight with minimal body roll. :shrug:
I only noticed the leaks when inspecting the system. It may have sagged a bit in the front, that was more likely just related to the age of the springs though.
I guess I'm the outlier here. I had a 2003 Sport with 237,000 on it when I got rid of it and XREAS was still good. I'm currently driving a 2010 Limited with 221,000 miles and, once again, XREAS is leak free. I'm going to be pissed if I just jinxed myself by responding to this post!
In both cases, used as daily drivers with the occasional snow storm thrown in, so maybe that has helped the system last longer...
