Wheel choice.
Has anyone seen or tried the level 8 gardian wheel on a 5th gen.
Having the black TE is making my wheel choice tough.
Who may be running this wheel spec
17x9 with 4.5 BS -12 offset. I want to pull the trigger and mount my 285 duratracs but I'm worried about rubbing.
On my 09 Taco I had 17x8 4.5BS and 285's with no rubbing and then changed to xd addicts 17x9 4.5BS -12 offset with 285's and had to trim lots and chop the body mount.
Need to know if ppl run 17x9 4.5BS and -12 with 285's W/O too much rubbing and I will be offroading
You will rub on the body mount slightly at full lock. Off road you will rub significantly with that set up.
If body mount mod is done should rubbing issue disappear? Also it seems like the 285/70.17 duratracs are bigger then te bfg at in the same size, or is it just me
black rhino are cool. maybe in an 18 with 275/65 or 285/65
pics on fj are 17 as well as on the 4runner.(sidewinder)
Black Rhino are cool I like the Lucerne. How's fitting 295's? Much trimming ? I'm just gonna run 275/285.
