Wheel offset and tire size
sgaustin83
Hi!
I’m terrible with wheel and tire specs.
My 2005 has Bilstein 2.5” suspension setup. I want a deeper 16” wheel, I’m considering the SCS F5 with -25 offset. Would this setup work without hub spacer? Do you think a 295 would fit without any need for trimming?
Thank you
yeah it should work without spacer, but you are going to need to clearance a lot for those wheels. They will stick out further due to the negative offset so your scrub radius is gonna be a larger area to clear.
AndiGarage
