Wheel spacers with stock wheels?
duratrac 265s no spacer vs 285s with spacer.
i'd never go back to the stock.
keep an eye out on the outlet section of spidertrax i got my set for 158shipped.
i've run spacers on oem rims w/ 285's for years. I rubbed on the mudflaps when turning in reverse (as in reversing into a parking space). When I removed the mudflaps, I didn't have any rubbing.
I would never go back to no spacers. I don't like the sunken in look.
Im thinking about pulling the trigger on these. The look does look much better with over without. Ive had my 2019 pro 3 months and this will be my first mod just trying to decide spacers, spacer lift since its on sale , or pedal commander. I read all the pages on here and only seen one person mention slinging rocks and he said he seen no difference. Curious if there is no change in slinging of rocks ect or more. Also I like the blue but can you even see the color of the spacer with the wheel on?
Yep, they do the job. It’s the same as getting aftermarket wheels with a different offset and they fill the wheel wells oit to get rid of that sucked in look. Once you do it, you can never go back.
Call or text me 717-319-2100 I’ll work you a deal for the spacers and the sprint booster, etc I have them all, since you are buying two items. Yes, you can see the blue if you kneel down. Most prefer the black since more stealth.
Burtman Industries Spidertrax wheel spacers, Now in black option
Sprint Booster SALE for 5th gen 4Runner, Limited time... - go here to see why this is great item
[MENTION=225449]kvincef[/MENTION] - can I use that pic in our gallery somewhere? Good job on that one!
Ordered a set in black from Burtman Ind. yesterday, had some issues with the payment side of things, but Jason got me sorted out, shipped same day! Thanks for your help Jason!
These are destined for my GX470, but I will likely get a set for the wife's 5th gen as well at some point. I may test fit these on hers first to see how much mud gets slinged up the sides and make the decision from there.
Depends largely on the style of wheel whether you'll be able to see the spacers through the spokes or not.
This is what I thought. I thought blue because I have voodoo blue but later on if i ever change the wheels dont want it to not look right and mesh. So Black it is.
I have just installed spidertrax spacers and I am experiencing little shaking at around 55-60 mph. Really like the look. But think it is a hub spacing problem even they said it is hubcentric. Am I the only one that has this problem? My truck is new with less than 2000 miles and tires are perfectly balance with no vibrating before the install. It is a little frustrating.
I have the TRD Pro wheels and when I added the spacers I also got a shake at highway speeds.
I think if your tires are even SLIGHTLY off balance, having them offset from the hub further exaggerates it.
I had no vibrations without them. I also felt a bit more feedback into the steering wheel from bumps, etc.
But, I also think it was a bit more stable in turns with the wider stance though. Not to mention it looked PERFECT.
I ended up taking them off :( But would like to try them again, just didnt want to spend the money to have the tires rebalanced if that wasnt the problem.
Rub?
I have a 2011 Trail Edition with stock wheels and tires. Does anyone know if 1.25” Spidertrax will cause rubbing in the wheel wells?
Hey Jason, just ordered a set in black. Can you get them to me by Tuesday? Thank you!!
Thanks for your order. If you can add some pics after you install that would be cool. @BP22
Shouldn't be an issue. You can text me at 717-319-2100 and I'm sure I have some pics with then on a trail somewhere.
Both colors in stock right now. These have been hard to keep in stock but have em right now. ALSO, these do INCLUDE all lugs needed, 24 new lugs to mount etc, also come with red threadlocker INCLUDED.
again, ofr those with TRD pro's can you post your lift size you did with the spidertrax wheel spacer?
Love mine!! Made the stock OR wheels look good enough that I decided not to replace them...
