wheel spacers
cd121082
So I was thinking of getting some wheel spacers. Reason I was thinking about them is cause i got some wheels at a really really good deal but the backspacing i figured out after the fact would require me putting in some spacers.What I was wondering is how do people feel about using wheel spacers.
Also what would you suggest for spacers. thanks
This is going to get ugly. This is such a biased topic. I run spacers now and have ran them before. My only, obvious, advice is to purchase brand name spacers (spidertraxx, all pro or g2) steer away from the ebay crap. Torque them on, do not use an impact gun. Little loctite doesnt hurt either
No spacers for me, thank you! Although, they can be used safely ... But, they better be checked often, IMHO...
there is no need to check them, in fact checking them is more dangerous than leaving them be.
you are supposed to liberally apply red-locktite to the threads of the studs, which has a breaking torque far outside of the rating of the stud. proper installation of red-locktite requires atleast 700 degrees of heat to release the adhesion. furthermore, the material that the spacer is made out of, assuming were talking about spidertrax, is 6061-t6 billet aluminum - which is far, far stronger than the wheel itself. the studs spidertrax uses are forged american slugs that are heat treated to exceed ANSI standards.
what this means is this: proper initial installation will have you torque 10% above threshold, with liberal application of red-locktite. 500 miles later, the lugs need to be broken, cleaned and liberal re-application of red-lockite and torqued to spec. after this, no regular maintenance is required - because they're not going anywhere.
by rechecking the torque and providing undue maintenance - you are bypassing the whole point of using locktite all together. the rotational stress from a 30-36" long torque wrench trying to tighten on said nut will ruin the locktite. thats why regularly checking them is more dangerous than not, assuming you installed them correctly in the first place.
how many of you don't realize that every dually pickup truck is running a factory 6" spacer in the front?
Stock wheels with spacers? Fine.
Custom wheels... with spacers? Please do yourself a favor. Do it right and get the desired offset from the start. Paying money for a custom set then paying more money to ADD rotational mass to the system makes no fukn sense.
yeah i realize that now but i got them at the 4wheel part show brand new set for $100. So another $200 for spacers is not a bad deal i think.
what do wheel spacers do? how would they affect 4runner with stock wheels and no lift?
Wheel spacers are exactly what they sound like. They space out the wheels from the hub. They give you a wider stance.
What kind of wheels did you get for $100? A whole set?
Wheels
[MENTION=69819]FactoryRide[/MENTION] yeah I went to the 4wheel parts jerp and truck fest and got them in the swap meet area.
Don't buy eBay brand wheel spacers, the lugs that hold on the spacer to the hub have a tendency to strip due to the lack of quality of the lugs. Spidertrax are the way to go.
