Wheels spacer vs backspacing wheels
achha64
Hi there,
What is the best solution to get a wider looks by running 265/75/16 ??
Now with my LC wheels my tires sit just at the limit of the limited flares.
I want the wheel to look a bit wider, just a bit out of the flare.
So what is the best solution? Shoul I get a back spacing wheel? Or a wheel spacer?
Which one will cause the most issues? Will the wheel spacer affect my steering system? ( rack and pinion?
ThNk you
Just to throw thi out there:
Did you try the link within the Tutorial & Documentation sub-sticky?
3rd Gen FAQ, Tutorials, & Documentation Reference v2
http://www.toyota-4runner.org/3rd-g...faq-tutorials-documentation-reference-v2.html
It is to a visual wheel backspacing calculator that shows the different settings on backspacing and how it affects the wheels relation to the vehicle.
Its tricky which is why I posted the link to the calculator.
