Does the top of the radiator have an olive drab color to it or is it black? Original radiators have that olive color.
Hmm.
I just ordered the original Denso(made in Japan)/Toyota 16400-75181 Radiator, for my new/old '02 Limited for $333 shipped@Boch Toyota South. These are supposed to be the real deal, that rolled off the production line with the vehicle. Wonder if it'll be OD?
Seeing that the latest Denso 221-0508s are made in China, I think I'm gonna go with the tried and proven, as no matter how I paint it, I cannot view the cooling system as something to skimp out on.:shocked:
Is there a difference in the radiator? cause I wonder the part number is different and price is considerably higher then the oem I bought.
camel back Toyota Genuine Factory Part
Part Number: 16410AZ011
Radiator assy 3.4 LITER,
PARTS: Warranty and Service radiators are included in a special Toyota program.
Item #1 on image
$119.85
toyotaparts deal
Toyota 16400-75180 RADIATOR ASSEMBLY
Part Description Radiator Assy
Replaced By 16410-AZ011
Manufacturer Toyota. This genuine Toyota part is guaranteed by Toyota's factory warranty.
Your Price: $116.91 Retail Pric
From what I understand from my research, the 16410AZ011 is supposedly the Toyota/Denso part currently made in Taiwan(Please correct me if I'm wrong) with mixed results, and the 16400-75181 is the new/old stock Japan made radiator, hence the premium(about 4X more expensive).
I think this is correct despite the Taiwan Rad saying it is a Genuine Toyota Part on the box. Camelback told me they haven't sold the more expensive radiator in a long time even though it is available.
I am not expecting the Denso to last 20 years but who knows? I had to buy three (three 4runners in the household) and was not going to pay $1000.00 for radiators. I plan on doing scheduled coolant changes to prevent corrosion.
Three 4Rs? I surely understand your situation.
Ideally, how many miles should one go before a coolant flush?
The radiator that came with my 4R, looks generic with no data plate and the reservoir is filled with orange goop, which appears to be rust/coolant medley.:mmph: It overheats and spews coolant from the release valve on the reservoir tank cap when idling.
Makes me wonder if that's the result of the previous owner pouring tap water in the radiator?
Coolant flush depends if you are using Toyota Red or Toyota Pink coolant (do a search). You may have a bigger problem than a radiator though......
I am wondering if the pink milkshake is also an issue with the Champion? Should I still plan to use a separate bypass cooler with the Champion?
