WhiteKnight Build - (Smallfry's rebuild)
smallfry
2002 Toyota 4runner Limited, as of 8.2.14
Specs
2002 Limited Toyota 4runner
3.4L, automatic 4x4
197,xxx miles
Current Setup:
Sonoran Steel 1.2 Lift
Bud Built Front Skid
Stubbs Welding Sliders
Tacoma Whip Antenna
Rear diff breather extension
Remove running boards
265/75/16 General Grabber AT2
Tundra 231mm brake upgrade
Bud Built belly skid
Elocked rear axle 4.30 gears with a 100 series LC diff lock dial and Slee elocker controller
AndyMod 2.0
Lik Skips Fuel Tank Skid
Sonoran Steel rear LCA
Shrockworks bumper
CBI Rear Bumper
PIAA 510's
Lightforce 170's
FJ Cruiser Rims
Lightracing UCA
Till I pick the vehicle up on Monday (going though detailing right now). I posted a photo of the same year 4runner and color that I purchased.
The lineup for the next two weeks sounds real neat.
Well, not as neat now. The $$ I had saved up is now going to paying the car off completely since there was a hicup with the loan. In the long run it's probable better.
Yeah, I'd rather be stock for a little while than have payments :trophy:
Well, i's official I own the vehicle out right now. So no payments. :banana::bluejump:
Lift and tires will have to wait a little while longer.
Updated as of 1/2/12
Running boards removed
Bud built front skid installed
Had the P0420 error code pop up on me so the rear O2 sensor got replaced and I cleared the code. Fingers crossed that it doesn't come back.
P1040053.jpg~original
After crawling around the underside of it for the past 2 days I haven't been able to spot any rust and the underside shows to signs of it ever being offroad.
Small update - more less parts waiting to be installed :nerd:
Cobra 75 WX ST cb
Wilson Little Wil magnet mount antenna
Stubbs Welding HD-SKO sliders
A/C control module is out being repaired, fingers crossed
Replacement b-pillar panels
Tundra brake upgrade (231mm, just got in the last few parts I need for it)
Suspension lift ordered - if anyone knows what I've had on my last (2) 4runners you know with what I company I went with :fro:
Got the climate control unit back today and I'm happy to say that it is working fine now and no longer has a mind of it's own.
I dont think ive ever seen a pure white 4runner quite like that. Every white one Ive seen either had gray bumpers and flares, or black sport flares, or chrome bumpers. That thing looks awesome! i love it
I take it back.Grrrrrrrr!
Two new issues have pop up with this dang unit.
1. All the buttons function now but at times when you adjust the temperature or the fan/blower speed it does the opposite of what you want.
2. The blower/fan no longer works. It was working before I sent the unit off to be repaired but now it doesn't work.
Any ideas?
Get a new one from a junkyard. Ive also heard of the temp sensing unit on the limiteds failing and causing problems.
Any ideas?
Quick question, where did you send your unit off to?
delislerebecca
