It's not the width of the tire that's going to help you. It has to do with the proper offset and back spacing of the wheel itself. Either that or wheel spacers is how it's done.
Do you have any side profile pics of that setup?
Im running 285/70/17 Nitto Ridge Grapplers on stock TRDPro wheels and 1.5 inch wheel spacers. I rub slightly on the body mount right now. I also have Icon UCA so I may try to get the caster set forward a bit to see if I can get the rubbing to stop. :AK47:
I'm running 285 Trail Grapplers 17" rims with negative 10 offset with spidertrax spacers 1.25". I also have aftermarket UCA. I had to do a body mount chop because I was not clearing at all. I also had to trim a lot from the bottom front fender flares. My tires stick out a little pass the bushwacker fenders. The picture angle doesn't really show.
You had to trim the bottom of the fender flare? Or did you mean the fender liner?
I'm definitely looking for something similar to your set up. Do you have any more pics you can share?
Your stance looks good. My option other than wider tires is just swapping out my 1" wheel spacers for 1.5 or 1.75" but I wasn't sure how much stress it would but on my bearings, etc.
Have you had any issues? And what brand of spacers are you using?
No issues so far. I'm running a set that I bought on amazon. I originally wanted spidertrax but they only make them in 1.25".
I had to trim both the fender liner and fender flare. I'll take more photos later on tonight when I get off from work and pm you.
It doesn't look bad, but I want to go wider and have my tires stick out more.
Ocean Beach and Golden Gate Park windmill in the background? Nice to see another Mag grey TEP in SF.
^ adjusting wheel backspacing/offset probably best bet but imo that's a lot of $$$/work. Did you give your eyes some time to get used to it? FWIW, I think the wheels and truck/stance look great.
Unrelated: what sliders are you running?
With a 3" lift and 33 x 12.50 i had to chop the body mount, move the fender liners as far forward as possible which passenger side is only up to the water res, trim out an angle of both front bumpers, and also cut and hammer/fold in the pinch welds.
hammer/fold the pinch welds? That doesn't sound fun. Are you running wheel spacers as well?
