whos rear spacers fit?
Id spend the 80 bucks and get the coils, the ride will be so much better and I think you would be much happier in the long run.
Thanks. Spacers are short term, until we have a few other factors sorted out. How will it fit in the new garage, how far will the hatch open, how are we going to use the truck now the twins are 3yrs. what summer rims, spacers, and, How much $$ leftover after suspension mods on the 911...
hamiltonj2w1 are you saying that the same result in stance will be achieved as the 1.5 rear spacer with a coil over for $80 more, yet you will get a better ride quality? What are other benefits of the coil over and whats the difference in terms of install complexity?
The stance will not be the same since the sping is a 2in spring and the spacer is a 1.5 the op wanted a 2in spacer. Yes the coil spring will ride better and also will not sag over time due to the extra preload from a spacer. They both go in the same since you have to remove the spring to install the spacer
