Why no oil gauge?
Just hope these motors aren't like the old 3.0. My 95 had an oil pressure gauge, and it would bottom out idling. Never turned the oil pressure light on though. Found out why, the Toyota FSM says the low pressure switch won't come on until the pressure drops below 5 psi.
I have yet to try one of these dongle/iPhone/Android gadgets. Many report that custom PIDs are needed for non-standard reporting.
I looked up the scan gauge II XGAUGE FEATURE. cost is $160. I can get it for $120 at advance auto. reading the instructions you have to program an empty memory slot with the proper coding like this
SCANGAUGEII
XGAUGE CODES
GAUGE : TFT/Transmission FLUID Temperature
TXD : 07E021D9
RXF : 032180000000
RXD : 2810
MTH : 00070064FE70
Notes : DEGREES F
this is for only transmission temp. tool can be programed for other vehicles also and other displays you may want to constantly monitor.
someone must have used this on the forum .
I'd be interested in this if we were guaranteed a way to look at all the important operations of the engine/trans.
SCANGAUGEII
XGAUGE CODES
TXD : 07E021D9
RXF : 032180000000
RXD : 2810
MTH : 00070064FE70
Notes : DEGREES F
goddesszilla
