Will 05 sport wheels fit 07 SR5?
4Runnewbie
Good morning all. Will the 05 17" sport wheels fit an 07 SR5? I ask this because I know some models have different brakes. Also will the offsets be the same? My 07 has the optional 17" wheels already but I like the look of the sport wheels a lot better. Thanks in advance.
Yes, you can mix and match any 17" wheels. Or even the 18" wheels if you want. The only time you may have an issue is if you try to put wheels smaller than 17" on 4Runners with the larger brakes.
And yes, offsets are the same.
The sport wheels will fit and I'm pretty sure that the offset is the same. I'm getting ready to sell my 17" Sport wheels (04) with newer tires (forget which ones as I just got it in Dec) if you're interested?
The sport has the bigger rotors up front, which means minimum 17" wheels - moving wheels from a Sport to SR5 is not an issue (the SR5 lets you put on 16" steels for winter if you want to for instance, but it's not an option on a Sport)
I would assume that the Limited is the same as the Sport, correct ??
I don't think so actually. I tried to just check in the old brochures but it's not mentioned there so I cannot be sure. The sports rotors were 13.3" which oddly enough is the std for the 5th gen.
TerryNap61
