Will a 265/70R17 fit as 4th gen spare?
frankvh
Hi gang,
I've searched the forums but can't find this one answered.
I'm purchasing some 265/70R17 Revo's. They seem to be a highly regarded tire, and with the winter snow beginning to fall, now's the time! But do I buy 4, or do I buy 5? The question is, will this larger tire fit in the spare tire well of my 2005 Sport-model 4runner? When I say "fit", I mean "fit when normally inflated". I know I can deflate it to fit, but I can tell you that when I'm changing a tire in the snow in sub-freezing conditions, I don't want to mess around pumping it up first! Does anyone have a tire this size as a spare?
Thanks a lot.
I'm pretty sure I've read on here that it does, tight, but it does. I know you searched, but it can be found in a search, so it might be hard to find, but i'm pretty sure it would be in a thread about tire upsizing.
I have BFG AT KO - 265/70/17 tires, including the spare. I also have a hitch in the receiver. The spare easily fits, and stays put. When lifting the spare, I push the tire toward the front of the 4Runner, until the rear of the tire fits behind the hitch. Then I let go and draw it up until tight.
Agreed' I have the Revo's 265/70 17's and
the spare fits fine, I also have the hitch. I put the spare tire lock on I had no problems getting the spare to go into it's space
Has anyone replaced their tires with 265/70/17 and left the spare 265/65/17 and had to use the spare. If so, were there any problems. I'm wondering if the spare MUST be up-sized!
Koz
fo'runner said:
I need to know if a 275/70-17 would fit into the spare compartment!!!
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
265/65-17 6.8in 15.3in 30.6in 96.0in 660 0.0%
275/70-17 7.6in 16.1in 32.2in 101.0in 627 5.2%
265/70-17 7.3in 15.8in 31.6in 99.3in 638 3.4%
That is what I got off of this website: http://www.miata.net/garage/tirecalc.html
I don't think it'll fit. There isn't much space for the stock size tire and you barely have room for the 265/70-17
Koz
I'd avoid using different size tires on the same axle, even for the spare. There's just too much to worry about--ABS, stability control, even the full-time 4wd for V8 4Runners.
If nothing else, the differential will be working overtime even when driving straight (to compensate for the differences in tire diameter).
I might be safer (and less expensive) to just match your spare tire and avoid a potential disaster!
Many members have replaced and installed the spare with the 265/70/17 and had no problems.
Koz
Koz
I have 265 70 r17 BFG's with the stock spare on a mess up rim(crub got in my way). I never got around to getting another. If i do get a flat, i inflate the donlap, and deflate the BFG on the same axle. I figured this will get me at least home.
One daywhen I get time to go to the tire shop and get another.
workingwheelswnc
