Will bigger spare tire fit?
Thanks for answering my question everyone! Yup figured it would hang a little lower if it did fit up in there. Luckily it won't be under there but a couple months, until my rear bumper is made and installed.
Cool. Out of pure curiosity only, what rear bumper are you going with, if you have the liberty to tell?
I know you already got your question answered but I fit a 275/70r17 KO2 under there no prob, wouldn't imagine a 285 would be much different as it isn't really a tight squeeze.
We're going with a dual swing out with jerry can holder on one side and tire carrier on the other from CBI Offroad. And thanks for the advice for the bigger tire fitting!
Half the people on this site probably run 285s on 7" wide TRD Pro, SR5, or similar Toyota OEM wheels.
That doesn't mean it's right - that's like saying "half the people in your classroom wear their underwear ON TOP of their pants, so it works fine" LOL
FYI, I did do a search and came up with no real answers, much like we get from you.
Now go take your nap.
I’ll just leave this here...
http://www.toyota-4runner.org/5th-gen-t4rs/108167-will-285-70-17-fit-factory-spare-tire-location.html
3 links to threads containing the information you seek. 30 second search using google. Type in “5th gen T4r” and then whatever you are looking for. But I assume you already knew that because you read this in the stickies section at the top of the 5th gen section.
http://www.toyota-4runner.org/5th-gen-t4rs/208458-you-new-prospective-5th-gen-4runner-owner-need-help-searching-start-here.html
And Yes it will fit.
If you need a slight bit of clearance you can also let all of the air out of the tire. Then fill when necessary with on board air.
Only way to fit the spare on my Dodge truck.
I am reading your signature and it states you have 295-70-17 tires. If that's the case, that size won't fit under there. This is just a forewarning heads up if you decide to go that route.
295 fits, just hangs low, however still above the rear differential.
hmm maybe a small all terrain 295, but i know for a fact my 295 trail grapplers don't fit under there, and the OP signature states he's running SST Pro's which are just as aggressive as the trail grapplers.
But, every truck is different I have a 2012 maybe the 2014's and up have more room.
I've been wondering about running a 255/80r17 spare. Its almost the same diameter as my 285/70r17 but its a thinner tire that would increase clearance and fit the narrower stock spare whee. Is anyone doing this?
Really
RIP departure angle
Let's think about this comment.
Do you really think that a person in Colorado with big knobby dirt tires on their really clean Toyota 4Runner really cares about departure angle? I mean REALLY!
The only departure angle MIGHT be a departure from a parking garage at Denver International.
This discussion is like the discussion about people discussing the toughness of rims and how they might crack or bend.
GMAFB
I have had:
6 FJ40s
1 FJ55
2 4Runners
and two shitty framed/rotted framed Tacomas
and I have done a variety of off-roading after building these trucks and have
NEVER cracked a rim!! I am not saying that it can't be done, I am saying that air pressure and driving technique lead to broken parts.
Sno Dawg
erinobr2000
