will XD Series 778 with 285/60R18 fit 2012 Limited?
Vlady
Has anyone tried this config,. on a 2012 Limited? stock suspension. will this fit wihtout rubbing?
Wheels: XD778 Monster, 18x9 with 6 on 135 and 6 on 5.5 Bolt Pattern
Wheel Size: 18x9
Offset: -12
Backspace: 4.53
Max Load: 2200
Finish: Matte Black
Tyres: DynaPro MT 285/60R18
Thanks in advance.. and yes.. I did the search before posting.
that´s the config. the salesperson told me people here in Panama are using with the 5th gen, but I´ve read, different offset recommended in this forum.
soon planing on ARB Bullbar, OME lift 2.5" and roof rack. (it´s a US$5K budget) plus US$2K in wheels and tyres..
Vladimir R.
Wheel Size: 18x9
Offset: -12
Backspace: 4.53
Max Load: 2200
Finish: Matte Black
Vladimir R.
Yep, That looks like a good fitting wheel and tire combo. :boink:
You may have minor rubbing on the front inner fender liner because your going up to a 9 inch wide rim. I doubt it though as your tire diameter size is about exactly the same diameter as stock.Easy fix if you did.
The offset changes in relation to the width of the rim so maybe that's why the offset recommended you read is different .
Here's a chart to help you understand offset better.
You will just barely touch the body mount at rear of front well...but only at full lock in reverse. Also only on driver side. Will be close but not enough not to use those. How much will depend on that MT tire. The -12 offset is the contributing factor but really is the best offset for that 9 inch rim. Will give your truck the look you want.
