Day 17
Discovered that my left side innner tie rod is shot. It has a tear in the boot and something that looked like a Gerber baby food terd came out off the tear. So I will read up on it tonight, order the part and replace it.
I finished torqueing everything, and made sure everything that should, has Locktight on it. Blue medium strength is good for shocks. High strength and next set of shocks, you will hate the asshat who used it. I cannot over emphasize what a great product Permatex and Locktight thread lock is, so make sure you use the right color and strength, or you will regret it later.
I also did a mitivac flush of the break system. First (ignition off,) I drew out of the main reservoir as much of the fluid as I could, about four cups worth. I then replace that with clean fluid. Next(ignition on,) I went to the right rear side, (the passenger, side, to clear up the confusion caused by the FSM,) and vacuumed there until I got clean fluid. I replaced the drawn fluid in the reservoir and moved to the left side rear, and then vacuumed there until clean fluid appeared, again refilled the the reservoir, and moved to front right side, and vacuumed it, the results were stunning, as the fluid was horrible looking. See the photo. Refilled the reservoir, and did the left front, the fluid again was very dirty. DONT FORGET TO KEEP THE RESEVOIR FILLED IF YOU DO THIS PROCEDURE< OR YOU WILL SCREW THE POOCH!
The result was that I now have clean fresh fluid throughout the brake system, and should be good for a few miles, all other things remaining equal.
