Winter fuel economy?
thatoneguy
Anyone else's mpg seemingly going down this winter? I don't know if that's a normal thing for "winter gas". I'm struggling to get 16 lately.
My 94 22RE seems to get worse mileage in the winter also, I think it is a mix of the higher start up idle, higher normal idle once it is warmed up, and also I run my heater fan more, so I believe it is normal. It has been the same cycle since 94.
Does using the heater hurt it? I have my heater on 100% of the time lately.
Using the heater should not affect the fuel economy, but if you are using the Defroster, it may lower overall fuel economy. The defroster turns on the A/C compressor to dry out the air being forced through the vents, so that will contribute to lower than normal MPG.
also, the engine is cold, so it will be running rich for a bit to get it up to temp.
also, any idle/warm up time before you start driving.
you may see a slight decrease from the heater. the more current you draw, the more the alternator has to put out, putting just a bit more load on the engine.
but, as said above, its normal. also, the winter gas isnt as good, you'll get a decrease from that aswell. i went from averaging 20, to 17. and has been normal since owning it.
Mine always drops a little in the winter... letting the truck warm up more, driving in snow, drifting, colder temps.. all seem to take a toll on the MPG..
Haha, nice casual touch there.
I never knew using the defrost turns on the a/c compressor. I usually have it on the "fresh" setting as well.
I'm undergeared @ 4.10 on 31's, I live in a dense neighborhood with hills next to a university. I'm getting 15mpg 100% city right now, suddenly that doesn't seem so bad with winter. Beats walking.
4runner mpg
Our mileage definitely takes a hit in the winter, longer warm cycle, winter petrol, and increasing use of ethanol. We've yet to fill up after the new speedo head/cable, so I'll get a better idea of current mpg results. Generally we're getting 13-16 mpg city and 19-20 hwy(this is on E10, 87 octane). I think we would do much better on the non ethanol stuff, which I might experiment with.
Replacing the o2 sensor recently, helped to improve mpg results on our 1990 4runner.
regards
Your mpg goes down in the winter because the gasoline formula changes for the winter for emissions reasons.
It sucks, but that's your government at work.
patnewton
