wonder if tacoma baja suspension will fit 4runner
4RunnerTrail
The front end components probably would, but why? You can do a whole lot better aftermarket for a whole lot cheaper. Sounds like they are just adding a 2" lift spring in front and AAL or different leaf pack in the rear.
For the price you would pay Toyota for a set of those coilovers you could buy two sets of Icons and have a much better set-up. I do however really like the wheels!
Curious how they only went two inches...
the front end components probably would, but why? You can do a whole lot better aftermarket for a whole lot cheaper. Sounds like they are just adding a 2" lift spring in front and aal or different leaf pack in the rear.
for the price you would pay toyota for a set of those coilovers you could buy two sets of icons and have a much better set-up.
+ 1,000,000
By mid May we will have the total chaos 2" long travel kit and our long travel rear kit installed on our 2011 Trail Teams. We will post up the results when it is all said and done.
As a side note the Tacoma suspension won't bolt onto the 4Runner, since the frame changed in 2010 the lower control arm has bigger bushings and a larger bolt than what the Tacoma uses.
you sure about this? The ToyTec coilovers I have on my 4R are the same ones they sell for 05 and up Tacoma's and they bolted on just fine.
I'm referring to the actual lower control arm that the coilover attaches to. The bushings and the bolt that attach the lower control arm onto the frame are bigger than the Tacoma.
