wrench.n.wheel's '99 Millenium Silver Adventure Rig/Daily
Got the updated savage skids for Christmas from my wife. Stoked to get them painted and mounted
Did some wheeling as well near mount Shasta.
Bought all I need for the CB radio setup. Links below. Came out to $128 total with 5% as first time customer and free shipping. Not too bad.
Radio
Cobra 19 DX IV CB Radio | RIght Channel Radios
Spring
Firestik Medium CB Antenna Spring | Right Channel Radios
Right angle adapter
Right Angle Male-to-Female UHF Connector | Right Channel Radios
Antenna - 4' required
Firestik FS CB Antenna | Right Channel Radios
Antenna stud mount
Firestik K-4A CB Antenna Stud Mount | Right Channel Radios
Coaxial cable - 18' required
https://www.rightchannelradios.com/...able/products/performance-cb-coax-cable-rg-8x
Radio
Spring
Right angle adapter
Antenna stud mount
Where are you mounting the antenna? That medium spring will allow the antenna to hit the vehicle if you mount it too low, like on the tailgate mounts that most 3rd gens run. A heavy spring might be better suited for you if so.
I'm mounting it on the tail light mount that [MENTION=98153]MStudt[/MENTION] sells, SRQ also sells one:see link below. Per mstudt with the medium spring it doesn't hit.
srq-fabrications | Product Page
These are the ones that I sell.
If you plan on running a 4' whip you will need a heavy duty spring. If you're running a whip 4' or longer on a medium spring you will have some body contact at highway speeds. Running a heavy duty spring is really the best option.
The longer antennas couple with the medium spring might whip into the body, which is why you’ll see some vehicle use a tennis ball to keep it from contacting the body. I would recommend a heavy spring but there has to be other members that opted for the medium spring that could chime in and confirm. Just food for thought.
Posts 330 to 332 is from someone using the same style mount that was mentioned above. Black798's 98 limited build thread
I will let you know about the spring, if it doesn't work out its only another $16.
Spent the previous weekend installing the cb radio.
-Cobra 19 DX IV
-firestik premium 18’ coax
-firestik 4’ antenna
-custom made mount(I wouldn’t build another one, just buy [MENTION=98153]MStudt[/MENTION] antenna mount, it’s cleaner and you don’t have to do all the measuring and cutting/bending.
[MENTION=68460]Dezert4Runner[/MENTION] check it out!
-Cobra 19 DX IV
Nice work on the install. I know how much time can go into such a small fab project like the antenna mount, mine took a long time to get all the angles right since I mounted it above the tail light where there’s weird angles. It looks like you have room to add a backup or dust light with all those dimple dies too. Did you tune the antenna? That’s key to making it work right and not burning up your radio.
Yeah, first thing i did is go out to a massive open field with no power lines or hills/trees nearby and tune it. 1.1 SWR Channel 1 and 1.4 SWR on channel 40, couldn't get it any better than that.
Sweet rig, man! Making this a reference point for my rig's transformation.
I really appreciate that, there are plenty of much better customized rigs than mine, but I do what I can!
Impressive! I wish I have the tools and the know how to weld/fabricate metal bumpers like you did. The truck looks great!
2 years ago I knew very little about all of this, I buy tools when I do a project I would need them for, I figure the amount I save by not paying someone to do the repair I can use a portion for on tools. Most of it just takes time and patience, some of it takes blood and sweat.
Pretty happy about, I finally decided to do a projector retrofit.
- 2x Bi-xenon morimoto mini d2s 4.0 projectors (square lens)
- 2x panasquare shrouds(wouldn’t do it again, just doesn’t wow me)
- d2s: morimoto elite package(includes the below with *
* 2x 35w/ d2s morimoto xb HID ballast
* 2x d2s xb 5500k (35w) HID bulbs
* 1x motocontrol bi-xenon H4/9003 harness
- retrorubber glue
Low-beam
Hi-beam
- retrorubber glue
How much do you have into the lights? Nice work!
H.Sikina
