wtb: Front Grill Bar on Hi Lux as seen on TopGear
BRIAN4R
I'm lookin to get this grill bar for my 07 4R
Toyota-Hilux-9.jpg~original
Any suggestions on where to buy? thanks
as seen on TopGear
Toyota Hilux, "Top Gear" Climb Icelandic Volcano Just Before Eruption - WOT on Motor Trend
Hilux is a Taco correct? not sure if that would fit. Or are you looking for the company so you can find out if they make on to fit a 4Runner? I'd be curious to know more about this as well, thats a pretty cool looking lightbar
If memory serves the people that modified that hilux for them are some serious modders in Iceland. I am betting that is their proprietary bar. I am also betting that it isn't cheap.
they mention who did the mods on one of the hilux episodes, might be a good place to start looking.
its probably a one off custom bar then if it was some guys in iceland. Those guys do some amazing things to toyotas.
If that is the case you should find a fab shop and maybe get them to quote you, it looks pretty straight forward.
The only reason I'm doing this is to mount my new KC long range lamps, for snowy backroads to Tahoe this ski season...
I was thinking about doing this
kconbumper1.png~original
although resale, with holes in the bumper is no good...
I am sure you can get some slick billet or rubber plugs to cover up those holes. Its a black bumper so must be easier to do so. I wouldn't worry about two tiny holes in my bumper, it's a truck, its going to see worse!
very true, mines silver but good point..
pismo31-1.jpg~original
I was also thinking a bar would be an easier way to pull someone, or myself out of a ditch if needed
Doesn't look like Randy Ellis makes that last one for 4Rs.
BTW, I don't think I'd be pulling anyone/myself out using any of these bars shown. You need a bumper, front hitch, or the factory tow hooks for that. Even the first one posted would probably be ripped off by pulling someone out. If you look, you can see that he also has a semi-hidden front hitch I believe they attach a winch plate to.
:cheers: good point
I ended up just drilling and mounting my PIAA 520 ATP lights right to the top of the bumper. I was looking for a light bar, but said f-it, this will work for now. Looks good mounted directly on the bumper.
problem is, not sure if I love it as much as on the Hi Lux..
but it sure looks better than any of the other bars I've seen..
I'm sure if we would be able to get some wide fender flares like that hilux has, that bar would look pretty sweet on the 4th gen. But then again, if you put flares like that on a Runner, you'd need some crazy wheels//tires, suspension, spacers, etc... Would be amazing if someone would pull off a Runner that looks like that hilux. :naughty:
how did you mount them, use a bracket above and on the inside of the bumper?
any pics? thanks!
I agree :thumb3:
any pics? thanks!
I just spaced them equal from the center and drilled the holes. Clears the hood perfect and gives me a little more light. They are surprisingly stable.
If I cannot figure out a behind the Satoshi mounting solution, I may have to do exactly what you did. Thanks for the pictures!
