Xenondepot Hid Late for over a month
I waited a little longer than expected for my Xtreme 4300k w/Phillips kit. WELL WORTH THE WAIT. So happy with them. And the feel of quality is unbelievable. I cant wait to do fogs.
UNEEK- Where did you mount your ballasts/igniters/relay for your fogs?
The relay I mounted it on the upper corners of the radiator on the radiator support. It's the easiest if you remove the plastic cover above the radiator to get access and see the the location. You'll need washers as the existing holes are pretty big to thread a bolt and nut through.
I put the ballasts under the headlights on the headlight buckets/radiator support.
I attached the igniters on the headlight support arm/bracket under the turn signal.
