Yet another "Lift" Thread.
RPM04
I recently replaced the tires on my 04 runner, and went from 265/70/R16 to 265/75/R16. Tire place was unable to order same size, and I thought next size up would be ok.
These wheels sure take up a lot of space in the wheel well, and I notice very slight rubbing at full wheel turn.
I am leaning towards a DS KT09117BK 1" budget boost.
This truck does very limited off road, use the atv for that. But would feel more comfortable with some additional clearance around the front wheels.
I was also looking at their 2.5/1.5 leveling kit, but think that may be more than what I need.
All comments appreciated.
These wheels sure take up a lot of space in the wheel well, and I notice very slight rubbing at full wheel turn. What's rubbing? The fenderliner or the Upper Control Arm?
I am leaning towards a DS KT09117BK 1" budget boost. IIRC this is a 1" spacer that yields about 2" of lift. You mentioned ATV's. I making a leap and assuming an ATV trailer. If that's the case your 4Runner may look like it's dragging it's butt with the kit listed above and the trailer. If I were you I'd look at the Toytec. It's .5" thick and adds a little more than .75" to the front.
I was also looking at their 2.5/1.5 leveling kit, but think that may be more than what I need. Great lift, many have it and like it but if you don't want it don't do it.
See inserted text above and look at J.A.'s awesome 'fix the rub' mod at the bottome of his wheelspacer page.
Toyota 4Runner Wheel Spacers
I am curious, what model tire did you get? A small front spacer lift is a good idea. Corned have a 1" (of lift I believe) one.
Thanks for you response CJ3Flyr, lots of great info there.
I don't know where its rubbing yet, its been -15 degrees Celcius here for the past two days, and I'm not crawling under there to look right now.:nono:
I will have to go through more of J.A.s site.
Thanks again.
I got this tire:
It is available in the 265/70/R16, not sure why he said he couldn't get it in.
delislerebecca
