Uneek said:Average 19.5, about 85-90% highway. Low of 15.7, all city and high of 22.7, all highway. I have a 4WD as well.
predatorsniper1 said:Cool, thanks. DOES ANYONE KNOW WHERE I CAN BUY A V-6 MODEL REALLY CHEAP???
josh220 said:Between 11-13.4 mpg city and 18-19mpg highway. That's not driving it hard either, that's what I get when I don't take it over 2,000-2,500 rpm with my V8.
Don't plan on getting what it's supposed to.
charlier180 said:I get 15-17 mpg around town and 19-21 on the highway but I do have the older, 2004, V8.
Your 11-13 mpg does seem to be a little low.
Are you ALWAYS filling up your tank FULL when you get gas then calculating your MPG (not using the on board computer)?
josh220 said:Calculated it manually every time. The computer always read 13.8-14.2 but now it reads 13.5 after the lift. I find it to usually be off by 2 MPG, so i'm probably getting 11 right now.
Spider5 said:Unless you are realy nailing it to the floor a lot, there is something wrong. Check your wheels, brakes, tire pressure, etc. I'm running in the 17 range and traffic here is a *****.
keylay31 said:I would try resetting the computer... See if that helps. My great mpg is accompanied by 5th gear at 30mph.
josh220 said:I don't take it over 2,000-2,500 RPM. My tires are all at 34-36 psi (depending on if it's at night or in the middle of the day.) I check them regularly. I have even tried different gas stations, and different octane ratings.
Would you suggest I bring it up at the dealership? The computer has only gone up 1 MPG since I first got it, and now it has about 6,400 miles on it. I think this is just because I drove it harder at first, than I do now. So it probably has nothing to do with it bing "broken in," just better driving habits.
Spider5 said:I did gain a couple of MPG from very early on (break in period) but like 15 to 17 not 11. BTW I also have a lift and didn't see any change before to after installing it.
josh220 said:I reset it every fill-up. Otherwise it's pointless to even look at it because it will have the average from every time I drove on the freeway to outweigh my average when driving in the city.
josh220 said:I didn't have any drop from the lift, but I lost about 1 MPG with the bigger tires.
Not really sure why it's so low. It seems like to get 11-12mpg you have to gun it at every stop light and constantly run it to 3,000-4,000 RPM.
Roland said:you did allow for the bigger tires when calculating your fuel mileage right. I've seen larger tires actually effect the speedo by 10%.
Spider5 said:for 165/70 it is more like 3%
josh220 said:You mean 265/70/17. Not 165.
And I don't care if my speedometer is off by a little bit, it's the MPG that pisses me off.
