zuk mod w/ rubicon front springs??
T?@\7
Looking to put on my bj spacers tomorrow, and my friend who will be helping has a set of these springs. He put the rears on his truck..
I have OME leafs, how much higher do you think they'll jack my rear up? The truck is already a liitle ass high so I dont want it to go any higher. Thanks anyone
Ray
3-4"? I have no idea how big a front TJ coil is or the spring rate.
You could always put them in then cut to get the lift your after.
Dont forget about shocks and extended brake lines.
Unless you happen to find someone that has done the exact same thing on and identical truck (same wear on the suspension (sag), bed weight (cap, no cap, tool box, etc) etc), any estimate on the result would just be a wild ass guess.
Yeah, I should've known. Decided there was no real need for the zuk mod on my truck, as it has new OME leafs. The truck rides much smoother, its no caddy, but conpared to cranked t bars its NIGHT & DAY. For those who have the bj spacers, who also has the other stuff roger brown (4crawler offroad) recommends, like diff drop.....
I've been under the assumption diff drops are a "no need" type of mod. Thanks again , can't wait to get the tires aligned/rotated/balanced, I haven't done it in the 18 months I've owned her , woops
Tau
enunciatechive
