IPhone Users: OBD2 app with Transmission temps.
AZBub
UPDATED: 07/07/2019
I’m making this cause it was super annoying going through several different threads to get this to work. FYI you DO NOT need to buy a Toyota expansion from OBD Fusion to make this work.
This App: OBD Fusion by OCTech, LLC OBD Fusion on the App Store
It’s $9.99 but after trying DashCommand and others This appears to have the best interface.
Now. To get Transmission temp to read you need to do some trickery. THIS ONLY WORKS ON 1999 AND NEWER.
To connect to iPhone and NOT affect cell data do this...
As for using your OBD reader and sill have access to a network you will have to set up the OBD tool as a manual connection.
For FOSEAL it is...
Configure IP: Manual
Ip Address: 192.168.0.11
Subnet: 255.255.255.0
Rouder: 192.168.0.10
Once app is installed and you have gone through the instructions to connect to your OBD2 wireless reader you will see this screen.
Then click on Settings.
Then click on User Defined PIDs and press “New”
Enter the data from the pic below. Make SURE the formula is exact. You will have to then connect to your vehicle and confirm that it can read it. NOTE- change from ECM to ALL seems to fix the transmission reading.
Once it confirms you can play with the Dash however you feel.
Thanks for sharing this. I've had people ask me to recommend apps for I-phones but I have an Android and use the Torque Pro app. I'll refer people to this thread when they ask.
Nice job!
Out of curiosity,is that formula some variation on the conversion between Celsius and Fahrenheit?
No idea. I found it digging through page after page, post after post on the subject.
Nice job!
I had the same thought, but......
If it is, it is upside down and backwards. You use 9/5 to go from F to C. But then you subtract 32 First, not 38 after. To go from C to F, you use 5/9, then ADD 32. So, it looks similar, but I can't imagine how it fits together.
This is where I got the formula: http://www.toyota-4runner.org/3rd-gen-t4rs/154558-good-iphone-app-monitor-trans-temp-3.html
Also some good info here. May change the formula... http://www.toyota-4runner.org/3rd-g...rans-fluid-temp-other-things-your-iphone.html
Id be curious to try other formulas. if anyone cares to post them so I can copy paste.
I’m curious what value A represents....
There may be some offset in the trans temp in the ECU?
The coolant, air intake and trans temp should all match at cold start after the truck as been off for >12 hours or so. That would be the easiest way to make sure the equation is correct.
"A" should be the data pulled from the ECU (Japanese ECU = everything in SI units, *C in this case)
Apparently all temp sensors report zero at -40 (f or C--same temp) and the -38 should be -40. Now it starts to make sense.
The OP in the thread cited by the OP here corrects his -38 to -40 in this thread:
http://www.toyota-4runner.org/3rd-gen-t4rs/160717-how-monitor-trans-fluid-temp-other-things-your-iphone.html
See posts #6 through #9.
A is the first byte of data returned by the PID, B is the second, etc.
BTW, "equation" should be "formula"--not the fault of anyone here, but needs to be said.
I changed OP after researching it. [emoji106]
I can not get this to work, my vehicle is a 2000 4runner. All other features (gauges) work so I know it's not the OBD reader. Any suggestions?
If you look close it looks like you have a space after your A*, in the OP there is no space.
Which OBDII wireless reader are you using ?
I've been thinking of getting one as well, just want to make sure I get one that is compatible.
Great catch but unfortunately still no joy. I have Torque Pro on an older Android and the Trans Temp reads perfectly.
I have a 2000 and it’s been working for me. go through all your settings and make sure everything is correct. and JIC, only works when the engine is running.[emoji1744]*[emoji3603]
This is the reader I use. No problems been working like a charm ever since.
Car WIFI OBD 2 OBD2 OBDII Scan Tool Foseal Scanner Adapter Check Engine Light Diagnostic Tool for iOS & Android https://www.amazon.com/dp/B00W0SDLRY/ref=cm_sw_r_cp_api_i_1xBrCb9ZA4R17
I was looking at that one. Ive also found this one : https://www.amazon.com/Vgate-Elm327...UTF8&coliid=IC1YDHDH921PQ&colid=1VUDKH32WCQOT
Seems to be a slightly smaller profile which is nice.
Wonder if they work the same
[MENTION=122900]AZBub[/MENTION] one more thing , what iPhone are you using ? Which iOS firmware version ?
For reference , I’m using an iPhone 7plus on iOS 12.1.2
iphone 8 worked on 12.1.2 and it still works on 12.1.3
PRWhite
