Successful 5th Gen Key fob swap!
Just got mine. It came with the logo.
Took about 2 minutes to program. It works great. However it will only go into the ignition one way. I think they may have left a burr on one of the cuts
take some sandpaper and go around the key, dont sit there and file it down but you can clean off the burs.
Well just got back from an actual locksmith. It wasnt a burr, they cut it way to deep on one side. The locksmith said my key is useless now. It sucks cause it programmed and it works fine, but one turns when inserted one direction.
I called Sears about the issue and spoke to a manager who proceeded to tell me they weren't liable because I didnt buy the key from them. She went off on me about how her employees told me that they couldnt do it because it is a chipped key and that I "Made" them do it. Needless to say I called their corporate about it afterwards. So hopefully they will be buying me a new one.
Until then I have a key that only half works. Im thinking about just ordering an actual factory Toyota key instead. This one does feel kinda cheap, and the casing on mine does not snap shut all the way on one side. There little chip thing inside it sticking up too high for it to close all the way.
if you have the same FCCID as i do ill send you my extra one, its uncut. Mine dont feel cheap at all. Since i worked in parts for Toyota i couldnt tell a difference. I even went back to my old dealership to get it traced, i asked my friend to tell the difference who has worked in parts for 15+ years. he couldnt tell which was which.
Let me know.
Let me know.
That would be awesome man. Let me know what you need from me.
my FCCID is HYQ12BAN
If thats yours let me know.
If you want to let that key go I will gladly pay for it. I was going to order from that link you sent me but I only want 1 key and don't really need 2. If not its no big deal.
Just got mine in and tried it on my 03 SR5. The remote programmed fine, but I wasn't able to get the immobilizer programmed with the instructions given. The light was blinking 2-1 which, from the pdf, simply means registration has failed but I'm not sure what for. Tried it about 4 or 5 times and waited up to 2+ minutes. Kind of bummed :(
mine took two times to take and i waited a LONG time until that light turned off. I'd try a few more times.
I've had bad luck with those style of keys. My old Lexus key fob had the buttons just like that, and they just didn't stand up to how often you would have to turn the key. The plastic would start cracking at where the key itself meets the plastic. I would then superglue it, then that would last awhile longer, then start cracking somewhere else. Eventually I'd have to replace it. I went through all 3 dealer keys within 5 years or so.
each time did you happen to do the whole process each time? or just do the programming then do the immobilizer?
I did this entire procedure each time:
1. Take the new key and one master key that can start your 4runner(old key) into the 4runner with you and close the driver's door.(immobilizer light should be blinking)
2. Insert old key, remove old key, Insert old key, remove old key,
Insert old key (immobilizer light should be off from the first insertion)
3. open and close driver's door six times (immobilizer light should be off)
Step 2 and 3 need to be done in less than 35 seconds(pdf says 35 seconds)
4.remove the old key. (immobilizer light should come on(steady on, not blinking))
5. insert the new key(immobilizer light should be blinking)
Then just sit there and wait, after about one minute the blinking immobilizer light should go off and you're done.
Whole process need to be repeated for any additional keys, the just programmed key could be used as the "old key" for the additional keys.
If there are 5 master keys registered with the immobilizer, it won't accept any more(and I don't know how would it tell you this, so just do a erase if you can't get it to work after trying for a few times). You have to erase them using a similar method(bring in just an old key, insert+remove one more time and open+close one more time, after the 7th close of the driver's door the immobilizer light will stay lighted for one second, remove the old key quickly after that and all but that one you just removed are erased.)
And even tried erasing all the master keys and doing it again.
Pretty sure I am following directions correctly since the immobilizer light is flashing or not flashing when it is supposed to except when trying to program the new key, it flashes twice quickly and then once and does that over and over.
Thanks to Hobson & this forum! Key arrived quickly with Toyota logo. Ace charged $0.75 to cut the key. And programming worked 1st try for both remote & immobilizer.
I got mine to work after a couple tries. I like the new look. I bought the keychain for $10 at the dealer. Locksmith charged me $10 to have it cut. The Locksmith charges $95 to have it programmed. Thanks again guys!
UPDATE: The red hold ''panic'' button does not seem to work like my old fob. I press and hold it and it only beeps once. Anyone have any idea as to what the issue is? Fob or programming error? I really don't use the panic button that often but it is handy when I'm looking for my 4Runner in a large airport parking lot.
You're welcome! I love this forum, it just cost me a whole lot of money! HA!
