Prerunner build
drbyrdman
Not really a Prerunner build
Been building my 2wd 2005 Sport 4.7 for awhile now. Lots of work done.
-Total Chaos upper control arms.
-Total Chaos lower control arms
-Total Chaos3.5 lift spindles
-Total Chaos CHROMOLY ADJUSTABLE REAR LINKS
-Fox extended coil overs with Wheelers 700lb springs.
-Fox rear 2.0 shocks.
-Front sway bar removed.
-Skyjacker Suspensions SBE702 - Skyjacker Extended Sway Bar End Links and
-Addco 2301 rear Anti-Sway Bar Kit
-MT LT rear HD springs
-Icon rear air bump stops.
-Spintech exhaust.
-AFE CAI
-Metaltech front tube bumper.
-10,000 super winch. Syn. rope.
-Piaa spot and flood lights.
-Method 17x9 wheels.
-12 volt mod for both plugs
-LED driving lights
-Tinted windows
-ARB 50qt frig.
-140000 Pull Pal
-Smoker kit
-Drilled/slotted Max brakes
-Console safe
-Tuffy storage box
-Alu-cab fridge tilt slider
-315/70/17 BFG All Terrains
-488's and Tru Trac
20160922_131526.jpgScored a ARB frig. and 14000 Pull Pal for 700 bucks today:dancin:
Moved the plug in for towing. Got a 295/70/17 to fit. Added a ARB hitch
Wow! what a differences driving. Nice and tight and goes straight down the road. Thanks ORW,Wheelers and Total Chaos
Looks good.
I think I met you a couple Saturday's ago in front of the muffler shop in Poway. We talked a bit about your 4runner. I was getting a smog done next door.
Yes there is a lean. I am fixing it with the spindles. The driver side coilover is maxed out and Im putting a trim spacer in the back.
aFe POWER 54-82502 Magnum FORCE Stage-2 Si Pro 5R Cold Air Intake System
Added an AFE CAI today. Works pretty good. Changing muffler to a Spintech on Sat.
Made this with an ARB hitch and a N-Fab rear bumper
patnewton
