New Southern Style Speed Rear Bumper Prototype Installed
Why place spare tire on passenger side of rear window? You lose visibility. Maybe I am missing something about functionality?
It doesn't matter where you place it ... drive side or passenger side. You lose visibility. If you put it in the middle you lose all space that could be used for a JeriCan or rotapax or even a maxtrax mounting point etc..
I always thought it as a counter balance for the driver. The rear passenger side of almost every car is the lightest corner. Which mean it should balance the car out more.. Thinking Corner Balancing ...
yes, corner balancing, because race truck.
Do you have a side profile of how big the gap is from the tire swing from the rear hatch? That has been my only dislike about other models offer. Can't wait to see what it would look like with out a ladder and jerry cans. Trying to keep things as minimalist as possible if I make the jump.
Ill get some pictures with those components removed since it only takes a few minutes anyway
If I got this (good possibility combined with a Hybrid front, just drive down from Mississippi to save shipping), I'd probably just want the tire carrier. Once I get around to installing a bumper-mount spare the next thing I would do is figure out a way to install an aux gas tank in the former spare location.
Looks awesome!
Literally what we will be working on after this trip is creating 10-15 gallon aux tank that maybe pumps into the main tank from a switch or when it detects the main tank is low.
multi-quote. it changes lives. :hippie:
hint: multi-quote is the little button just to the right of the "Quote" button at the bottom of someone's post. Select as many as you like then just hit "Quote" on the last post you want to quote. Just in case you don't want to reply to everyone individually.
PS this is a very slick design. Glad to finally see a full bumper (aka no bumper cutting needed) option. Don't think i will need one for awhile. But if i was to go with one, [MENTION=110183]SouthernSS[/MENTION] is good people and i would never regret purchasing from Kevin! Now you just gotta get the 10-13 hybrid bumper out for the masses. :zoom:
life saver!
Design looks promising. Would like to see some pics of the gaps... around the body/tailights and the bumper... That seems to be the gotcha with this type of design.
Instead of custom-fabbing an air-tight steel or aluminum tank, may I suggest a cheaper structural frame/skid plate supporting a pre-formed fuel-grade bladder? Maybe something from these guys or similar: Racing Safety Fuel Cell Bladder Tanks You can draw up a tank to fit the exact dimensions of the 4Runner in CAD. A flexible bladder would be less likely to rupture in the case of a rear-end collision.
And don't forget the safety foam!
+2 ....close ups.
:whip:
I will post more pics from more angles but what cant be seen is that inside the bumper is 3-4 inches of space in there and at the edges of the bumper is about an inch or a bit more of space between fenders and the tail light area.
To better explain i can fit my entire hand not quite to my wrist but around where my thumb is and run it almost all the way to the back tail light region so its tighter in the back and bows out a bit in the front almost like the rear of the truck is sitting in the bumper like a chair
fargo4x4-albums-ig%3A+%40fargo4x4-picture36936-close-ups-some-spacing-but-its-about-inch-down-inch-out-bowing-out-away-vehicle-basically-if-vehicle-sits-inside-bumper-like-chair.jpg
fargo4x4-albums-ig%3A+%40fargo4x4-picture36935-close-ups-some-spacing-but-its-about-inch-down-inch-out-bowing-out-away-vehicle-basically-if-vehicle-sits-inside-bumper-like-chair.jpg
this angle really shows how much room there is... and there is plenty! but that being said we are going to trash our rig this coming month to make sure it is absolutely good to go before it goes into production.
fargo4x4-albums-ig%3A+%40fargo4x4-picture36939-angle-better-shows-gap-allow-independent-flexing-frame.png
also here is a close up of one of the rubber footed ladder stoppers
fargo4x4-albums-ig%3A+%40fargo4x4-picture36937-example-one-rubber-footed-ladder-stoppers.jpg
I will post more pics from more angles but what cant be seen is that inside the bumper is 3-4 inches of space in there and at the edges of the bumper ....
I think I could live with that. It's not terrible. I'm looking to completely eliminate the stock bumper cover.
As far as shifting on impact... say if you came down unexpectedly hard on a rock or something... would the bumper shift up at all? I'm looking to avoid any contact with the sheet metal if at all possible.
:boink:
Bunkstaff
