Utah_4runner
Hey everyone, I'm new to the forum here and new to Toyotas as well which is why I need some extra help.
The problem is that my 4runner has long crank time intermittently. It doesn't matter whether it is hot or cold, or if it is a cold start or starting it within five minutes of turning it off I will either have a super quick start or a super long start. The longest it has taken is probably 7 seconds of cranking before it will start. It always starts, but its starting to worry me because I don't want something to fail and leave me stranded.
The battery tests good, the alternator tests good, the starter is cranking strong, I have tested the fuel pressure regulator with a vacuum gauge and it holds pressure, and the fuel pump relay is good.
I hooked up a fuel pressure gauge today and got these results. When I turn the key to on (not starting the vehicle) it sits at 0. When the vehicle is started the pressure goes up to 42 psi. After turning off the car the pressure drops to 38 psi, and stays above 35 psi for 5 minutes. I am used to GM vehicles, which prime the whole fuel system when the key turns to on. Is it normal that my 4runner stays at 0 when I turn the key to on? Shouldn't turning the key prime the fuel rails and get the system up to pressure?
If the pump is operating how it is supposed to, do you have any ideas of what could be wrong? Can the fuel pressure damper fail? Could it be a bad ground like 03-04 Tacomas had a problem with?
Another thing to note is that there are no fault codes that come on while driving, BUT if I turn the key to on, wait 10 seconds, then repeat twice, the ECU throws 3 fault codes. The codes are P0441 (Evap system incorrect purge flow), P0455 (Large evap system leak), and P0456 (Small evap system leak. These only come on if I "prime" the system 3 times and then start the vehicle. I get the codes as well as the VSC and traction control light. When it happens I am able to clear them and they don't come back on until I do what is described above.
I've looked around the forums and haven't found anything quite like this. Any help is greatly appreciated. Thanks!
