$10K KDSS Repair!!
ovmiowa
Hi all, Our local Toyota dealer quoted me $10,000 to fix the KDSS system on my 2010 4R Trail, with 220K miles. The KDSS light comes on now and then, and they said it was very rusty (salty upper Midwest roads) and leaking slightly from the unit. The $10K is to replace the unit and all four lines. Does this sound right to you? Many thanks for sharing your insights!!
For that age of vehicle and that quoted cost of repair, I'd just pull the connector and turn off KDSS. That said, it'd be worth getting a quote from a non-dealer repair shop.
I've heard of expensive KDSS repairs, but that is ridiculous. My guess is that dealership doesn't have the equipment to perform the work. If it completely fails, it would be a great time to install an aftermarket setup.
Yep, those high tech systems are great (I guess) when they work, but when they don't it's often way too expensive for most of us to have pay to get it working right again. Can it be removed/replaced with normal sway bar system like Xreas can with normal shocks?
I second dr.KDSS, Dom is super passionate about what he does and is a super cool dude
are you running stock suspension?
another option is to take out the kdss system and upgrade your spring coils to a heavier weighted version to negate the loss of the sway bar.
this is my plan once my system fails.
or like others have stated, just replace the parts that need to be replaced.
Second this.
Also, take it to a Lexus dealer and see what they say. They see KDSS on every LC and GX, so they likely have more experience with the system.
x4 reach out to dom aka DR.Kdss. this isnt voodoo, its just a hydraulic system, and he's repaired them.
you can unplug the white connector under the dash by the gas pedal area and the kdss light will always be on ;)
yeah, with the stock suspension, kdss vs no kdss was night and day. After upgrading the suspension, the difference is lot less noticeable. If you're running a stock suspension, can just spend the money on a new suspension and just unplug the kdss wire by the module.
How bad is the rest of the frame? It really is a bummer how 5G’s are so susceptible to rust and if l lived in the rust belt, I would not own one.
It really might be time to beat it on down the line as even a $3-$4000 repair would be tough to swallow if the rest of the frame is rusting badly as well.
$10k is absolute insanity. KDSS is really nothing high tech and shouldn't be that hard to replace. Hell, it's a $1750 option from Toyota.
If it were me, I'd just buy new suspension for about $1000. I have a Dr. KDSS switch in mine with Fox 2.0 suspension. You can definitely feel the difference with it off, but it's certainly tolerable on the road. I'm sure it's still better than a stock SR5 or TRDOR without KDSS based on what everyone says about nose dive and body roll on them.
Like everyone else has said, it shouldn't be that complicated to fix. And it shouldn't be that expensive. It's unlikely that it needs new lines. Unless stainless steel lines are rusting now. KDSS failures are very few and far between. I wish my fox suspension lasted as long as KDSS.
A complete control actuator/accumulator from a low mile GX 460 will run you about $5-600. Lexus GX460 Stabilizer Control Actuator w/ Accumulator 2010-2020 OEM | eBay
New ones are only about 1500.
The hardlines are stainless. Seems pretty unlikely that they are rusted.
I think you may need to find a new dealer.
If braided steel lines can fail on my water heater in 12 years (lines that do not flex daily, and are only subject to line pressures of 60 PSI) I imagine they can fail in automobiles a lot sooner. Rust was not even a factor. Pinholes in the underlying rubber.
For hard pipe, ask any plumber why do pipes leak in the middle where there’s not even a joint? Corrosion from the inside. No visible rust may be present upon observation. I’m thinking some sort of galvanic reaction?
A 10k quote is that dealer basically saying that they don't know how to, or simply don't want to work on it.
A ridiculously high quote so you'll go away. In other words.
I worked at some places back in the day that used that tactic. That and other examples of poor customer service is why I walked away from consumer car repair, in disgust.
Good luck OP.
edcultural
