2 JL 12"W1 or 1 JL 12"W3 ???
Which one?
  • 2 JL 12" W1
    Votes: 0 0.0%
  • 1 JL 12" W3
    Votes: 8 100.0%
  • Total voters
    8
I'm assuming they will all be the same size?
I'd probably just do the W3 if your running that amount of power.
Is there anyway you can get a different amp?
Why would I need a different amp, the W1 handles 125rms and the W3 is rated at 300rms. 250 watts rms is plenty, plus Im not trying to go deff anymore. I did enough of that when I was a kid.
From what I've seen the w1's will take 300 each and the w3's will take 500 each. I think the w3's look a lot better.
What size are you going with?
07sport027.jpg~original
07sport028.jpg~original
07sport029.jpg~original
07sport014.jpg~original
07sport015.jpg~original
07sport016.jpg~original
07sport017.jpg~original
The W3s will not take 500 watts of true power! I've seen people who have put a single 500/1 on a W3 but the gain was turned down significantly. I've got 500/1 on a W7 with the gains about 3/4 and its all I can take.
I would do the single W3 with the 250/1... You will not be disappointed with either setup you pick though!
1- 12"!!!!!!!
Mount it up to be easy to remove to load the Runner up with gear, and you don't need 2 since you're not into db drags and stuff, that'd be a waste of space and $, IMHO...
Dynamat works wonders in the back hatch too!
w/the amount of power you plan on using just get one 12" or even a 10" for that matter don't spread that small amount of power over 2 subs
If you have a JL 250/1 amp and want to keep that amp, i would sugest running 2 W1's But the real question is, what are you looking for? The most bass you can get? Or the cleanest bass you can get? If its the most...the 2 W1' s it the right way to go...you will be almost doubling your cone surface area...therefore adding +3db from the extra sub. If you want a cleaner bass...but not as much...go the W3 route. In my opinion thoug...if the rest of your system is pretty much stock....why go for ultra clean bass b/c the rest of the system isnt up to par. go with the W1's.
bgmac said:
You make me wonder sometimes Clemson!
Whats the title to this thread say? :bash:
I must have glanced over that. It was late when I posted too so I was probably tired.
Glad I know know. :bigok:
