johnnywofee
2010,2011,2012 4Runner Battery Tray Installed (Tray$25, Screws$6)
Hi Guys,
I finally order screws (M8X1.25, length 20mm, Qty=6, $6) from Ebay. I used a piece of transparent sheet (those toy packing material) to map the screw holes position. I then use my home tools (Dewalt drill) to drill 3 holes on the bottom of the tray. Please refer to the attached photos and would be appreciated to give your insights :
1. One of the screw must be cut to about 12mm in total length in order to screw in.
2. These screws (qty=3) created additional 4mm thickness at the bottom of the tray. Please give ideas, is 4mm too much? Shall I order other screws (with thinner screw heads or plastic screws instead) ?
3. I would like to proceed with minimum cost investment (current, I only spend $31 on the tray and screws). Before I buy the expensive battery (Odyssey PC1200), what is the best way to go from this point to make sure I can successfully install the battery? I was wondering if I could insert the battery from the top since there is a metal clip (the in-take air filter box) which could block the way.
4. I also notice that the power steering reservoir has to be removed in order to slide in the battery. Is it easy to un-click it ? Any potential issue of unplug this reservoir from its mount? Shall I asked a mechanic to do this instead?
Hi Guys,
