2010 Front Turn Signal Bulb Replacement
kbpember
On my 2010 4Runner, I need to replace the front passenger side turn signal bulb. Can someone point me to a video/guide for this or explain how to reach the front turn signal bulbs to replace them? There seems to be no easy access points like there are for the rear bulbs and I don't think I can reach them from underneath as they are farther out than the headlights.
Thanks!
Welcome to the forum!
There are step by step guides with pictures in the owner's manual that walk you through replacing almost every bulb in the truck.
While it may be a little difficult, I replaced mine from underneath. Once you take off the plastic plates on each side (sorry I don't have pics but held on in about 4 places) u can reach your hand up a little past the fog lights. You could also try reaching down from the top by removing the plastic guard under the hood but I have not tried.
you need to turn the wheel all the way to the right/left depending on which side needs replacing and then remove (or partially remove and fold back) the fender liner. This will allow you to access the rear of the headlamps.
Thanks for the advice!
After much searching I was able to find my manual and go through the steps suggested on here/in the book. All is well again in my little corner of T4R land!
Happy trails!
If you are talking about the small "corner" lights, I would highly suggest you just break down and go LED...you'll never have to replace them again.
I went to replace the driver side turn signal in my 2011. The manual shows that there are screws. However, there are actually some sort of clips. I thought maybe they fell out except there are no screws on the other side either.
jisoo200
