2011 Trail MPG
Mike I wish I could get that kind of milage, out of mine. It's mostly stock, with only the stubby antenna mod, and E-Rated BFG AT KO's (stock size) and the best I can avg is about 17.5mpg (hand calc and computer are with in .1 always), I got 19 on my last tank but, this tank back down to mid 17's. My Daily commute is 13 miles, 3 city 10 hwy. I'm even running my tired at 55psi to try and squeez more out of them (emailed bfg and that's the pressure they recommened for the e-rated 265/70R17's). Thinking of droping it down to 45.
Are the Duratrac's really that better of a hwy tire then the BFG AT KO's? Could it be the diffrence in location? I even try to keep the eco light on the time, I've kind of made a game out of it to see how long I can keep it on. :)
According to TireRack, the Duratracs are 5 pounds lighter, but I doubt that 20 pounds will make that much difference. The tread pattern might, but I doubt you'll ever find a direct comparison.
My combined mileage is around 17.5 for the commute we take in the morning, but when I reset it as I turn onto an on-ramp for highway driving, I get the previously posted numbers. And I run my tires at 44 unless it's fully loaded, but there is nothing wrong with 55 as long as your kidneys can take it. :)
The ECO light is nice, but not reliable. Focus more on the RPMs, keep it as close to (or below) 1500 and you'll get a much better result. The ECO light says on when in "cruise control" no matter what the RPMs are, so it's really more of a gimmick than a useful indicator. Most of my low mileage comes during acceleration (passing, on ramps, long hills, and taking off from stop lights) and I find that the closer gas gets to $4/gal the less I am tempted to goose the throttle.
My combined mileage is around 17.5 for the commute we take in the morning, but when I reset it as I turn onto an on-ramp for highway driving, I get the previously posted numbers. And I run my tires at 44 unless it's fully loaded, but there is nothing wrong with 55 as long as your kidneys can take it. :).
I bet it's you resetting your computer that's the diff since I don't reset mine until I fill up. I'll play around with that and see what my results are. :)
Edit:
Now that I think about it when I do monitor the Consumption Info in the NAV when I am on the hwy it's sitting midway between the 20 and 30 mpg mark most of the time, as long as I keep it under 65, push it to 70 and it drops just below the 20 mpg line.
Yeah, if you are just going from fill-up to fill-up 17.5 sounds normal for mixed driving. I was getting 18 before I started adding things like the rack, tent, cargo, dog, kitchen sink...
Mike raises an interesting point. Physics is not my field, but it seems to me that a change in tire weight is quantitatively different than simply adding curb weight to a vehicle. Cyclists go for lighter tire/wheel combos to reduce the inertial mass, which allows for quicker spinning up to speed, especially from a standstill. In the same sense, the engine is applying torque to the inertial mass of the wheels+tires, especially in start stop situations. Increasing the weight of the tire/wheel by 12.5% could be enough to register a noticeable difference in mileage, no?
Brad
This was it, going home from work this morning I got about 19.5 mostly up-hill and had a head wind, coming to work tonight mostly down hill no real wind to speak off I get 23.7 mpg
I reset my trail on the Hwy last night and it read 31mpg!!! By the time I could stop to take a photo it was at 28 something. We'll see if it stays there.
I have 28,000 miles on my TE, have changed the tires out to stock size T/A KO's and consistently get 20.5 mpg on my daily commute which consists of 3 miles city at 40mph, 40 miles freeway at 70mph and 3 miles rural at 60mph each way. before changing the tires I was getting about 1mpg better and if I pump the tires up to max I can get the higher mpg but the ride suffers. Towing my 3500 lb travel trailer I get 9-13mpg depending on grade and head/tail winds.
The mileage on my TE was very good when new, but now after 10,000kms it's noticeably worse. I'm averaging 14.5l/100km which is 14MPG. That's driving it nice too. The only thing I've changed was putting Goodyear SA's on my TE. Before that my average was 13.5l/100kms. Still nowhere near the mileage I was getting when it was new. I have lost about 100km of range on a full tank..
Oh and gas is almost $5 a gallon here now... :( $1.29/litre for regular
Rob
Jesse1
