2013 SR5 level and 33" tires - will it work?
I now have the Westin Step bars added and am going to do some "Plasti-Dippin" :) I experimented first on my wifes Avalon this weekend..
Nice, I picked up some 275/55-20 Toyo open country at's on some tuff wheel T05 20x9 with 4.8" backspace. They meassurr about 32.1" diameter. I'm going with billy 5100's on front and 1.25" spacer on rear. I don't want to change UCA's. Did you? Any problems with caster after your alignment? Tires wearing evenly so far?
@hrod alignment checked out fine and shouldn't cause any uneven wear on the tires. I didn't change the uca on my set-up. I wanted the open country's for mine but they didn't have the size I needed...
Awesome thanks for the help! I ordered some UCA's anyways just in case. I heard the caster when you go over 2" in front goes closer to 0 degrees making highway driving squirrelly. I'm going to try with out uca's but if I need the I will go ahead and install them. I'm only looking at 2.5" in front. Might even try 1.75" if wheels will allow it, but I doubt it.
I've got +2 Caster on stock UCA's on 2.1" lift on Icon coil overs. It drives great, not squirrelly.
David
[MENTION=99579]Tylerdh[/MENTION]- That truck looks good, man! I like the choice of rims. There are way too many big wheels out there with the tackiest looks. Thanks for doing it right:cheers:
[MENTION=76550]cbielat[/MENTION] vossen has a sick line up of wheels. It was between vossen and zenetti for my wifes '13 avalon. I went with zenetti as nobody else had one that looked like the torinos that we got. Yeah, I dont think vossen even offers a 6 lug wheel. The black rhinos had the clean spoke look that I wanted with the newer concave design. Thanks again!
[MENTION=66483]hrod79[/MENTION] I just checked the spec sheet from my alignment, my caster is 2.0 and 1.6. Honestly I don't know what that means, but the place that did it said it wouldn't affect tire wear. That was a concern after dropping over $1600 in tires...
Daniel Frost
