2014-2016 behind grill light bar mounts.
This thread alone made me join this forum!!!!! Best looking mounts that I have found.... Can a noob get in on these bad boys????:clap2:
Just a heads up, I have a few more sets in stock ready to ship. Not sure if or when I'll be making more of these.
Thank you everybody for the positive feedback through out this project, and thank you to the members who ordered a set thus far!
Brad
neat set up but I'm looking for a set that sits in front of the grill.
Think I'm going to that route, if you produce a set of brackets to do that please post.
Thanks,
I have the new 20" RIGID E2 Combo mounted up to OP's Bad AzZ mounts, and its a slick setup for sure! I tested it out tonight and OP did a heck of job with his design.
I want to thank OP for taking the time out to design and then make a few more for us to enjoy. Big Thanks!!!!:banana:
On to my first observations with the new E2.... I am not overly impressed with the light output... I believe the grill is blocking a significant amount of light. Has anyone cut out the grill around the light bar and noticed a significant increase in light output?
To put this in perspective, the E2 has more light output than the open SR2 10" combo I had on a Jeep, its just not that much more illumination.
I don't think I want to give up the stealth of this setup unless if it would be a major improvement.
Thoughts?
Thoughts?
Look at [MENTION=103267]Saker[/MENTION] build thread. He has photos of both grill and no grill with the light bar.
Thanks for the link and I have read that thread. However he didn't have it behind the grill first that was mentioned and then do the cut-out to compare the light output. It is a super clean install.
The comparison of the light output behind the grill vs unobstructed is what I'm after. Sorry for not being more clear the first time around.
Hey [MENTION=137080]Dog Runner[/MENTION],
If you are stating I didn't have it behind the grill first, in fact I did.
Look here at the LED LIGHT BAR INSTALL thread. You should see it behind the grill then the grill cut out & faceplate installed.
It made a larger difference that I thought it would.
If I have misinterpreted what you stated, please inform.
Hope this helps.
Hope this helps.
Sorry about that Saker. I must have missed that. PM sent.
Thoughts?
I really appreciate the kind words, posts like these make all the hard work and late nights worth it!! No corners were cut on these mounts that's for sure!
[MENTION=103267]Saker[/MENTION] just wanted to thank you for your continued input and support on this mod. Your original thread is what inspiring me to build these mounts. Your the man!!
[MENTION=133346]BradBrad619[/MENTION],
Thank you sir. I was unaware that I inspired your product. From the photos and the comments, it seems you made a quality mount indeed.
Whatever you do, don't discard your pattern as some may need more.
Thanks again ! :becky:
PRWhite
