2014 LED tail lights
2014 led
Don't let the dealers steer you wrong the harness part number is 8155535400 and it is plug and play one you have them in whether you have the limited, trail and sr5
Woo-hoo!!! Someone finally went thru 100% When you get the chance, can you post up a pic of your ride from a distance so we can see both tail lamps?
Led
Another angle
The harnesses come with sockets but no bulbs. I wonder if the existing '10-'13 bulbs will work or if they're different.
Mission accomplished. All you need to install the 2014 tail lights on a 2013 and below model is a wiring harness (1 for each side) part number 8155535400 everything else is replacing the originals with the 2014 tail light assemblies.
And the award for best first post goes to...xem228. :trophy:
Well done sir.
Where do you get those? I've only seen ones that have like a bluish/silvery coating and they glow amber when illuminated.
There is one from pilot that is decent. silver coating and amber light. Darker than stock amber but still amber. I got some off amazon a while back. 20 bucks or so.
Also you can tint stock bulbs with high temp sliver paint. Very light coat....basically a misting. Doesnt work on DRL's or anything with constant on because the paint peels but works with blinkers bulbs.
The top half of that lens is clear and the lower half is smoked. How about hitting the top half with some of that VHT tint in a can to match? I think it's called Night Shades???
No the pilot one is all chrome but glows amber.
LEDs would be ideal.
I did LED bulbs in my DRL's with an inline ebay P-N-P resistor type thing. They have been fine. But it was like 50 bucks with bulbs/resistor harness etc.
Okay, so this morning I had to go to the dealer to pick up a customers part that was not sent out to me. While I was there, I was talking to the parts guy about the sub-harness and he mentioned that one came in a couple of days ago on a stock order. I asked him to bring it out so I could inspect it and snap a few pics with my iphone. Unfortunately, I wasn't allowed to remove it from the bag. Basically it's exactly the same as the schematic that I posted up a while back. One end plugs directly into the T4R tail lamp wiring and the other end plugs into the '14 tail lamp via a small 3 pin female connector and 2 light bulb sockets. I didn't ask what kind of light bulbs this thing uses but I am pretty suer that the existing '10-'13 bulbs can be used.
Where to buy?
what website can I purchase both the 2014 Tail Lights and harnesses? Can someone post the part numbers for all the parts needed for replacing the 2010-2103 tail lights with the 2014 ones.
If I have to go to the parts center at dealership, part numbers are greatly appreciated. thanks.
The part #'s for the harnesses are on the pic I posted earlier right on the packaging. The part #'s for the tail lamps are on page 2 of this thread.
alexaturner
