2014 Side Mirror Bulb Access
the 2 cargo lights in the tailgate alone are worth swapping out the rest. those 2 really illuminate that area where the stock ones left me switching my headlamp on and off while out camping
Great info I am going to do the puddle lamps and the tailgate. I also think I'm going to swap the bulbs in the door. I know I don't want to change the over heads, we have that in our jeep and to be honest they are too bright and effect my nite vision
Thank you [MENTION=66390]ROBSCOOL[/MENTION] Excellent write up. Changing the puddle lights to LEDs went flawlessly. Thank you!
Here we go- it was actually way easier than I thought!
Step 1: remove back cover of mirror assembly. I marked the area with a red dot where you should start. Pull back and up with a slight pressure and the cover will pop right off. The tabs are strong, so dont worry about breaking them. Just be careful not to let it go flying and scratch up your paint.
Photo showing back of cover:
Step 2: that yellow wire leads to the puddle lamp. Remove the 2 screws from lower cover assembly. Next you need to pry off the lower cover. It's attached at several points, so the way I did it was wiggle it free on the right, then middle and then left and it came off pretty easily.
Photo showing back side of lower cover assembly, once removed from mirror housing.
Step 3: Twist the light socket from the lens assembly to reveal the old bulb and replace with your fancy new LED.
Reverse the process, reassemble and boom, LED puddle lamps.
Side note- taking this thing apart really explains all of the wind noise these things make while driving. There are no real seals or gaskets, so they just whistle dixie.
Hope this helps and let me know if you have any questions!
Just did full led install. This worked like a charm.
I see 2 lights in each mirror housing, but the only info i see is about swapping the single 194 "wedge" puddle light. Is the other one in there already an LED or what?
How much of a difference did the LED's make?
Just completed the install following ROBSCOOL's instructions. Covers popped out easily, no damage to the clips, and 20 minutes is about right on the install time. To answer the question above regarding the difference in LED v. Stock, I took pics with the stock bulb on driver's side and LED in passenger side in a dark garage. Very happy with the results. Many thanks to ROBSCOOL for the detailed instructions!
Light Stays on
Thanks so much for the removal instructions and all the input on this mod.
Anyone else reading for instructions ROBSCOOL isn't kidding about holding tight. I flung my passenger side cover off and watched it bounce across my driveway :frusty: hold that sucker tight, or be prepared for some damage.
I put some of these in place of the standard incandescents https://smile.amazon.com/gp/product/B0186P1MUW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
In fact, I put them all over inside the vehicle, and swapped out the puddle lights with them too. Also used these in my wife's Outback (even for taillight and driving light replacements). They work GREAT, and I recommend them! However, I noticed the ones I installed in the underside of my mirrors still have a faint glow to them even after the doors are locked and I've left it alone for 30+ mins. In fact, they dimly lit up the moment I plugged them in.
Perhaps a capacitor? Anyone else experience this? I mean, it's an LED, so I shouldn't be too worried about battery drain, but a little perplexed nonetheless. :confused:
This helped a ton. Thanks!!
Thanks to ROBSCOOL’s instructions, I was able to get access to my puddle lamps to install leds. That being said, my covers seemed to be on there pretty tight and it took a bit of force. While there was no major damage to the clips, I think I could see where it may have slightly chipped the catch on the mirror where the large clip goes ( on the mirror side, not the cover). I also think the covers pop off a little easier now than the 1st time, because I pulled them both again to recheck something. They still seem quite secure and fit perfectly, so I’m not too worried.
Any of you guys notice this? I’m pretty OCD, so it’s probably a non issue.
Photo of what I’m talking about:
I'm having the same problem with the faint glow all the time on the puddle light. Have you or anyone else on here figured out a solution?
You know, I've all but forgot about it. Doesn't seem to be a drain on my battery, and really doesn't make a difference. Let's see if anyone else chimes in with a solution though
Thank you ROBSCOOL!! Did the swap in about 20 minutes this afternoon. Your write up and pictures were a huge help!
Tried to replace the puddle lights this morning and I ended up breaking the clips on the painted mirror cover. fuuuuu
what are my options? can i glue the clips back together or am I eff'ed?
likely eff’ed if the clips hold pressure the way most of them do.
