2015 4runner Map Lighting Housing Removal
Need help in removing my 2015 4runner map light housing. Trying to remove the whole housing to do some repair. Any help would be greatly appreciated..
IIRC there are two small Philips head screws under the home link unit. What I do not recall is if those screws are actually holding the entire assembly up or if they just hold the smaller unit to the assembly. Ether way I do remember gently prying to remove a small portion of the unit, undoing a couple screws and then gently prying to remove the rest of the unit. There is a third screw but I am 90% certain that it is just holding a sub assembly together and not the entire unit to the roof. If you don't have a set of plastic trim removal tools I would get one, best $13ish bucks ever spent.
Also the wiring to the switches is easy to remove but there is a central wiring harness that was a pain, I had to remove the actual wiring from a tie down to be able to clear enough space to get the plug out (will make sense once your in there).
I can get you more details this evening if you need. Also curious as to what you need to repair in there.
[MENTION=83083]rigtec[/MENTION] has a great write up on this issue. He even addresses the difficulty in removing the small bulb with some scotch tape.
Edit: Sorry, I thought you were just looking to remove the bulbs and didn't completely read the first post. whoops!
Hahaha! Yeah unfortunately I never removed the entire lamp assembly, but now I get to see what happens to this guy when he tries to get it down :pop2: Cheers...
BillM777
